Datasheet LTC3107 (Analog Devices) - 6
DescriptionUltra-Low Voltage Energy Harvester and Primary Battery Life Extender
Pages / Page24 / 6 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 376 Kb
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. VSTORE Holding-Up VOUT. Voltage Sequencing While
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted VSTORE Holding-Up VOUT Voltage Sequencing While
LTC3107
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. VSTORE Holding-Up VOUT Voltage Sequencing While VOUT Transitioning Between (VBAT = 3V, CSTORE = 1300µF, Harvester Is Turned On and Off Harvester and Battery Power IOUT = 50µA, Holdup = 37 SEC)
VBAT 2V/DIV BATT_OFF VBAT VOUT OFF V V OUT BAT 2V/DIV 2V/DIV ON VSTORE 100mV/DIV VSTORE HARVESTER VOUT V BATT_OFF OFF BAT = 3.6V BATT_OFF HARVESTER ON 3107 G20 3107 G21 3107 G22 10s/DIV 500ms/DIV 5s/DIV
VOUT Ripple While Harvesting VOUT Ripple, Not Harvesting
VBAT = 3.6V VBAT = 3.6V 20mV/DIV 20mV/DIV (AC-Coupled) (AC-Coupled) 3107 G23 3107 G24 10ms/DIV 10ms/DIV 3107f 6 For more information www.linear.com/LTC3107 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
