Dual Very Low Noise Precision Operational Amplifier
Pages / Page
20 /7 — Data Sheet. OP270. 130. VS = ±15V. TA = 25°C. VCM = 0V. 120. 110. 100. n …
Revision
F
PDF / 329 Kb
Data Sheet. OP270. 130. VS = ±15V. TA = 25°C. VCM = 0V. 120. 110. 100. n ( T. URRE. d 70. R (. CM 60. BI UT. INP. –75. –50. –25. 125. 10k. 100k. TEMPERATURE (°C)
Data SheetOP2707130VS = ±15VTA = 25°CVCM = 0V120VS = ±15V1106A)100n ( T90N580B)URREd 70CR (AS4CM 60BI UT50INP40330 0 13 01 0 20 2- 2- 35 35 00 2 00 10–75–50–2502550751001251101001k10k100k1MTEMPERATURE (°C)FREQUENCY (Hz) Figure 9. Input Bias Current vs. Temperature Figure 12. CMR vs. Frequency 56VS = ±15VVCM = 0V4A)A)nm(5(NTNTRE3URRECURCT4YELSP+125°CF2FUP+25°COSUTAL–55°CT3INP1O T 11 14 0 0 2- 2- 35 35 00 0 00 2–75–50–2502550751001250±5±10±15±20TEMPERATURE (°C)SUPPLY VOLTAGE (V) Figure 10. Input Offset Current vs. Temperature Figure 13. Total Supply Current vs. Supply Voltage 78TA = +25°CVS = ±15VVS = ±15V76A)A)m6n((NTNT55RREURRE C4CUY LASP4BIUP3UTS ALINPT23O T 2 1 15 01 0 2- 2- 35 35 00 2 00 0–10.0–5.005.010.0–75–50–250255075100125–12.5–7.5–2.52.57.512.5TEMPERATURE (°C)COMMON-MODE VOLTAGE (V) Figure 11. Input Bias Current vs. Common-Mode Voltage Figure 14. Total Supply Current vs. Temperature Rev. F | Page 7 of 20 Document Outline Features Functional Block Diagrams General Description Table of Contents Revision History Specifications Electrical Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Test Circuits Applications Information Voltage and Current Noise Total Noise and Source Resistance Noise Measurements Peak-to-Peak Voltage Noise Noise Measurement—Noise Voltage Density Noise Measurement—Current Noise Density Capacitive Load Driving and Power Supply Considerations Unity-Gain Buffer Applications Low Phase Error Amplifier Five-Band, Low Noise, Stereo Graphic Equalizer Digital Panning Control Dual Programmable Gain Amplifier Outline Dimensions Ordering Guide
