Datasheet LTC3459 (Analog Devices) - 3
Description10V Micropower Synchronous Boost Converter in ThinSOT
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 226 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3459
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.3V, VOUT = 5V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS VIN
Input Voltage Range l 1.5 5.5 V VIN Quiescent Current SHDN = VCC 10 20 μA VIN Shutdown Current SHDN = GND 0.1 1 μA
VOUT
Programmable Voltage Range l 2.5 10 V VOUT Quiescent Supply Current SHDN = VCC 2 4 μA VOUT Shutdown Current SHDN = GND 0.1 1 μA
Reference
Feedback Voltage VIN = 3.3V, VOUT = 7.5V l 1.19 1.22 1.25 V FB Input Leakage Current Measured on FB 10 50 nA
Converter Performance
Peak Switch Current (VIN = 3.3V) L = 22μH l 60 75 90 mA tOFF Timer (VIN = 3.3V, VOUT = 5V) Varies by 1/(VOUT – VIN) 225 400 550 ns Zero Current Comparator Threshold L = 22μH 0 mA
Main NMOS Switch
On-Resistance VOUT = 5V 2.8 Ω Leakage Current VSWITCH = 10V, VOUT = 10V 0.01 1 μA
Main PMOS Switch
On-Resistance VOUT = 5V 4.2 Ω Leakage Current VIN = 5V, VSWITCH = 5V, VOUT = 0V 0.02 2 μA
Logic Inputs
SHDN Threshold (Rising Edge) 0.3 1 V SHDN Hysteresis 80 mV SHDN Input Leakage Current SHDN = 3.3V 0 50 nA
Note 1:
Note 3:
This IC includes overtemperature protection that is intended may cause permanent damage to the device. Exposure to any Absolute to protect the device during momentary overload conditions. Junction Maximum Rating condition for extended periods may affect device temperature will exceed 125°C when overtemperature protection is active. reliability and lifetime. Continuous operation above the specifi ed maximum operating junction
Note 2:
The LTC3459E is guaranteed to meet performance specifi cations temperature may impair device reliability. from 0°C to 85°C. Specifi cations over the –40°C to 85°C operating temperature range are assured by design, characterization and correlation with statistical process controls. 3459fc 3
