Datasheet AD8237 (Analog Devices) - 3
DescriptionMicropower, Zero Drift, True Rail-to-Rail Instrumentation Amplifier
Pages / Page28 / 3 — Data Sheet. AD8237. SPECIFICATIONS. Table 2. Parameter. Test …
File Format / SizePDF / 657 Kb
Data Sheet. AD8237. SPECIFICATIONS. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8237 SPECIFICATIONS Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4
+VS = +5 V, −VS = 0 V, VREF = 2.5 V, VCM = 2.5 V, TA = 25°C, G = 1 to 1000, RL = 10 kΩ to ground, specifications referred to input, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
COMMON-MODE REJECTION RATIO (CMRR) V = 0.1 V to 4.9 V CM CMRR at DC G = 1, G = 10 106 120 dB G = 100, G = 1000 114 140 dB Over Temperature (G = 1) T = −40°C to +125°C 104 dB A CMRR at 1 kHz 80 dB NOISE Voltage Noise Spectral Density f = 1 kHz 68 nV/√Hz Peak to Peak f = 0.1 Hz to 10 Hz 1.5 µV p-p Current Noise Spectral Density f = 1 kHz 70 fA/√Hz Peak to Peak f = 0.1 Hz to 10 Hz 3 pA p-p VOLTAGE OFFSET Offset 30 75 µV Average Temperature Coefficient T = −40°C to +125°C 0.3 µV/°C A Offset RTI vs. Supply (PSR) 100 dB INPUTS1 Valid for REF and FB pair, as wel as +IN and −IN Input Bias Current T = +25°C 250 650 pA A Over Temperature T = −40°C to +125°C 1 nA A Average Temperature Coefficient 0.5 pA/°C Input Offset Current T = +25°C 250 650 pA A Over Temperature T = −40°C to +125°C 1 nA A Average Temperature Coefficient 0.5 pA/°C Input Impedance Differential 100||5 MΩ||pF Common Mode 800||10 MΩ||pF Differential Input Operating Voltage T = −40°C to +125°C ±3.85 V A Input Operating Voltage (+IN, −IN, or REF) T = +25°C −V − 0.3 +V + 0.3 V A S S T = −40°C to +125°C −V − 0.2 +V + 0.2 V A S S DYNAMIC RESPONSE Small Signal Bandwidth −3 dB Low Bandwidth Mode Pin 1 connected to −V S G = 1 200 kHz G = 10 20 kHz G = 100 2 kHz G = 1000 0.2 kHz High Bandwidth Mode Pin 1 connected to +V S G = 10 100 kHz G = 100 10 kHz G = 1000 1 kHz Rev. 0 | Page 3 of 28 Document Outline Features Applications General Description Pin Configuration Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Architecture Setting the Gain Gain Accuracy Clock Feedthrough Input Voltage Range Input Protection Filtering Radio Frequency Interference Using the Reference Pin Layout Common-Mode Rejection Ratio over Frequency Power Supplies Reference Input Bias Current Return Path Applications Information Battery Current Monitor Programmable Gain In-Amp AD8237 in an ECG Front End Outline Dimensions Ordering Guide
