Datasheet AD8237 (Analog Devices) - 7
DescriptionMicropower, Zero Drift, True Rail-to-Rail Instrumentation Amplifier
Pages / Page28 / 7 — Data Sheet. AD8237. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table …
File Format / SizePDF / 657 Kb
Data Sheet. AD8237. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter. Rating. Table 5. Package. Unit. ESD CAUTION
Data Sheet AD8237 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Package Unit ESD CAUTION
link to page 7
Data Sheet AD8237 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4. Parameter Rating
θJA is specified for a device in free air. Supply Voltage 6 V
Table 5.
Output Short-Circuit Current Duration Indefinite
Package θ Unit JA
Maximum Voltage at −IN, +IN, FB, or REF1 +V + 0.5 V S 8-Lead MSOP, 4-Layer JEDEC Board 145.7 °C/W Minimum Voltage at −IN, +IN, FB, or REF1 −V − 0.5 V S Storage Temperature Range −65°C to +150°C Junction Temperature Range −65°C to +150°C
ESD CAUTION
ESD Human Body Model 8 kV Charge Device Model 1.25 kV Machine Model 0.2 kV 1 If input voltages beyond the specified minimum or maximum voltages are expected, place resistors in series with the inputs to limit the current to 5 mA. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. 0 | Page 7 of 28 Document Outline Features Applications General Description Pin Configuration Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Architecture Setting the Gain Gain Accuracy Clock Feedthrough Input Voltage Range Input Protection Filtering Radio Frequency Interference Using the Reference Pin Layout Common-Mode Rejection Ratio over Frequency Power Supplies Reference Input Bias Current Return Path Applications Information Battery Current Monitor Programmable Gain In-Amp AD8237 in an ECG Front End Outline Dimensions Ordering Guide
