Datasheet LTC1440, LTC1441, LTC1442 (Analog Devices) - 4
DescriptionUltralow Power Single/Dual Comparator with Reference
Pages / Page16 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 259 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LTC1440/LTC1441/LTC1442
C. V+ = 3V and V– = GND = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Power Supply
V + Supply Voltage Range ● 2 11 V ICC Supply Current IN + = IN – + 80mV LTC1440 0°C ≤ TA ≤ 70°C ● 2 3.9 µA HYST = REF (LTC1440/LTC1442) –40°C ≤ TA ≤ 85°C ● 4.3 µA LTC1441 ● 3.5 5.7 µA LTC1442 ● 3.5 5.7 µA
Comparator
VOS Comparator Input Offset Voltage VCM = 1.5V ● ±3 ±10 mV I + – IN Input Leakage Current (IN +, IN –) VIN = VIN = 1.5V ● ±0.01 ±1 nA Input Leakage Current (HYST) ● ±0.02 ±1 nA VCM Comparator Input Common ● V – V + – 1.3V V Mode Range CMRR Common Mode Rejection Ratio V – to V + – 1.3V 0.1 1 mV/V PSRR Power Supply Rejection Ratio V + = 2V to 11V (LTC1441) 0.1 1 mV/V V + = 2.5V to 11V (LTC1440/LTC1442) 0.1 1 mV/V NOISE Voltage Noise 100Hz to 100kHz 100 µVRMS VHYST Hysteresis Input Voltage Range LTC1440/LTC1442 ● REF – 50mV REF V tPD Propagation Delay COUT = 100pF Overdrive = 10mV 14 µs Overdrive = 100mV 5 µs VOH Output High Voltage IO = – 8mA ● V + – 0.4V V
Comparator
VOL Output Low Voltage IO = 0.8mA LTC1440 ● GND + 0.4V V LTC1441/LTC1442 ● V – + 0.4V V
Reference
VREF Reference Voltage No Load LTC1440/LTC1442 0°C ≤ TA ≤ 70°C ● 1.170 1.182 1.194 V –40°C ≤ TA ≤ 85°C ● 1.164 1.200 V LTC1440 (MSOP, DFN) ● 1.164 1.200 V ISOURCE Reference Output Source Current ∆VREF ≤ 1mV (LTC1442) ● 60 120 µA ISINK Reference Output Sink Current ∆VREF ≤ 2.5mV (LTC1442) 10 20 µA ∆VREF Reference Source Current 0 ≤ ISOURCE ≤ 1mA (LTC1440) ● 0.8 5.5 mV Reference Sink Current 0 ≤ ISINK ≤ 10µA (LTC1440) 0.5 1.5 mV ● 5 mV NOISE Voltage Noise 100Hz to 100kHz 100 µVRMS
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. 144012fd 4
