Datasheet AD8065, AD8066 (Analog Devices) - 8
DescriptionHigh Performance, 145 MHzFastFETTM Op Amp
Pages / Page28 / 8 — AD8065/AD8066. Data Sheet. Parameter. Conditions. Min. Typ. Max. Unit
RevisionL
File Format / SizePDF / 494 Kb
AD8065/AD8066 Data Sheet Parameter Conditions Min Typ Max Unit
AD8065
AD8066
POWER SUPPLY Operating Range 5 24 V AD8065WARTZ only: TMIN − TMAX 5 10 V Quiescent Current per Amplifier 5.8 6.4 7.0 mA AD8065WARTZ only: TMIN − TMAX 7.0 mA Power Supply Rejection Ratio ±PSRR −78 −100 dB AD8065WARTZ only: TMIN − TMAX −78 dB Rev. K | Page 8 of 28 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ±5 V SPECIFICATIONS ±12 V SPECIFICATIONS +5 V ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS SOIC-8 Pinout THEORY OF OPERATION CLOSED-LOOP FREQUENCY RESPONSE NONINVERTING CLOSED-LOOP FREQUENCY RESPONSE INVERTING CLOSED-LOOP FREQUENCY RESPONSE WIDEBAND OPERATION INPUT PROTECTION THERMAL CONSIDERATIONS INPUT AND OUTPUT OVERLOAD BEHAVIOR LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING LEAKAGE CURRENTS INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING WIDEBAND PHOTODIODE PREAMP HIGH SPEED JFET INPUT INSTRUMENTATION AMPLIFIER VIDEO BUFFER OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
