Datasheet MAX4172 (Maxim) - 2
ManufacturerMaxim
DescriptionLow-Cost, Precision, High-Side Current-Sense Amplifier
Pages / Page9 / 2 — Absolute Maximum Ratings. Electrical Characteristics. PARAMETER. SYMBOL. …
Revision4
Absolute Maximum Ratings. Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Absolute Maximum Ratings Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX4172 Low-Cost, Precision, High-Side Current-Sense Amplifier
V+, RS+, RS-, PG ...-0.3V to +36V Operating Temperature Range OUT ...-0.3V to (V+ + 0.3V) MAX4172E_A ... -40°C to +85°C Differential Input Voltage, VRS+ - VRS- ..±700mV MAX4172G_A ... -40°C to +105°C Current into Any Pin ...±50mA Storage Temperature Range .. -65°C to +150°C Continuous Power Dissipation (TA = +70°C) Lead Temperature (soldering, 10s) ...+300°C SO (derate 5.88mW/°C above +70°C) ..471mW Soldering Temperature (reflow) ...+260°C μMAX (derate 4.10mW/°C above +70°C) ...330mW Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(V+ = +3V to +32V; VRS+, VRS- = 0 to 32V; TA = TMIN to TMAX; unless otherwise noted. Typical values are at V+ = +12V, VRS+ = 12V, TA = +25°C.)
Operating Voltage Range V+ 3 32 V Input Voltage Range VRS- 0 0 32 V Supply Current IV+ IOUT = 0mA 0.8 1.6 mA MAX4172ESA ±0.1 ±0.75 V+ = 12V, V Input Offset Voltage V RS+ = 12V OS MAX4172EUA ±0.2 ±1.6 mV VRS+ ≤ 2.0V 4 V Positive Input Bias Current I RS+ > 2.0V, IOUT = 0mA 0 27 42.5 RS+ µA VRS+ ≤ 2.0V, IOUT = 0mA -325 +42.5 Negative Input Bias VRS+ > 2.0V 0 50 85 Current IRS- µA VRS+ ≤ 2.0V -650 85 Maximum VSENSE Voltage 150 175 mV MAX4172ESA ±8.0 Low-Level Current Error VSENSE = 6.25mV, V+ = 12V, V µA RS+ = 12V (Note 1) MAX4172EUA ±15 MAX4172ESA, TA = -40°C to 0°C ±20 MAX4172EUA, T Output Current Error VSENSE = 100mV, V+ = 12V, A = -40°C to 0°C ±50 V µA RS+ = 12V MAX4172ESA, TA = 0°C to +105°C ±10 MAX4172EUA, TA = 0°C to +105°C ±15 OUT Power-Supply Rejection Ratio ΔIOUT/ΔV+ 3V ≤ V+ ≤ 32V, VRS+ > 2.0V 0.2 μA/V OUT Common-Mode Rejection Ratio ΔIOUT/ΔVRS+ 2.0V < VRS+ < 32V 0.03 μA/V www.maximintegrated.com Maxim Integrated │ 2
