Datasheet LM124, LM124A, LM124M, LM224, LM224A, LM224K, LM224KA, LM2902, LM2902K, LM2902KAV, LM2902KV, LM2902V, LM324, LM324A, LM324K, LM324KA (Texas Instruments) - 7
Manufacturer | Texas Instruments |
Description | Quadruple Operational Amplifiers |
Pages / Page | 42 / 7 — LM224K. , LM224KA. , LM324. , LM324A,. LM324K,. LM324KA. , LM2902. LM124. … |
Revision | W |
File Format / Size | PDF / 1.8 Mb |
LM224K. , LM224KA. , LM324. , LM324A,. LM324K,. LM324KA. , LM2902. LM124. , LM124A. , LM224. , LM224A,. LM2902V. , LM2902K. , LM2902KV. , LM2902KAV
link to page 9 link to page 9 link to page 9
LM224K , LM224KA , LM324 , LM324A, LM324K, LM324KA , LM2902 LM124 , LM124A , LM224 , LM224A, LM2902V , LM2902K , LM2902KV , LM2902KAV www.ti.com
SLOS066W – SEPTEMBER 1975 – REVISED MARCH 2015
Electrical Characteristics for LMx24A and LM324KA (continued)
at specified free-air temperature, VCC = 5 V (unless otherwise noted)
LM124A LM224A LM324A, LM324KA PARAMETER TEST CONDITIONS(1) T (2) A UNIT MIN TYP(3) MAX MIN TYP(3) MAX MIN TYP(3) MAX
0 to 0 to 0 to 25°C Common-mode VCC − 1.5 VCC – 1.5 VCC – 1.5 VICR input voltage VCC = 30 V V 0 to 0 to 0 to range Full range VCC − 2 VCC – 2 VCC – 2 RL = 2 kΩ 25°C VCC − 1.5 VCC – 1.5 VCC – 1.5 High-level VOH RL= 2 kΩ Full range 26 26 26 V output voltage VCC = 30 V RL≥ 10 kΩ Full range 27 27 28 27 28 Low-level output VOL RL ≤ 10 kΩ Full range 20 5 20 5 20 mV voltage Large-signal 25°C 50 100 50 100 25 100 VCC = 15 V, differential A V VD O = 1 V to 11 V, V/mV voltage Full range 25 25 15 RL ≥ 2 kΩ amplification Common-mode CMRR VIC = VICRmin 25°C 70 70 80 65 80 dB rejection ratio Supply-voltage k rejection ratio SVR 25°C 65 65 100 65 100 dB (ΔVCC /ΔVIO) Crosstalk VO1/ VO2 f = 1 kHz to 20 kHz 25°C 120 120 120 dB attenuation VCC = 15 V, 25°C –20 –20 –30 –60 –20 –30 –60 VID = 1 V, Source Full range –10 –10 –10 VO = 0 mA IO Output current VCC = 15 V, 25°C 10 10 20 1 20 VID = –1 V, Sink Full range 5 5 5 VO = 15 V VID = −1 V, VO = 200 mV 25°C 12 12 30 12 30 μA Short-circuit VCC at 5 V, GND at –5 V, IOS 25°C ±40 ±60 ±40 ±60 ±40 ±60 mA output current VO = 0 VO = 2.5 V, no load Full range 0.7 1.2 0.7 1.2 0.7 1.2 Supply current ICC mA VCC = 30 V, VO = 15 V, (four amplifiers) Full range 1.4 3. 1.4 3 1.4 3 no load
6.8 Operating Conditions
VCC = ±15 V, TA = 25°C
PARAMETER TEST CONDITIONS TYP UNIT
SR Slew rate at unity gain RL = 1 MΩ, CL = 30 pF, VI = ±10 V (see Figure 7) 0.5 V/μs B1 Unity-gain bandwidth RL = 1 MΩ, CL = 20 pF (see Figure 7) 1.2 MHz Vn Equivalent input noise voltage RS = 100 Ω, VI = 0 V, f = 1 kHz (see Figure 8) 35 nV/√Hz Copyright © 1975–2015, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: LM224K LM224KA LM324 LM324A LM324K LM324KA LM2902 LM124 LM124A LM224 LM224A LM2902V LM2902K LM2902KV LM2902KAV Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for LMx24 and LM324K 6.6 Electrical Characteristics for LM2902 and LM2902V 6.7 Electrical Characteristics for LMx24A and LM324KA 6.8 Operating Conditions 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Unity-Gain Bandwidth 8.3.2 Slew Rate 8.3.3 Input Common Mode Range 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Examples 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
