Datasheet Texas Instruments LMC7211 (Texas Instruments) - 4
Manufacturer | Texas Instruments |
Description | Tiny CMOS Comparator with Rail-to-Rail Input and Push-Pull Output |
Pages / Page | 24 / 4 — LMC7211-N. www.ti.com. 5.0V and 15.0V Electrical Characteristics … |
Revision | F |
File Format / Size | PDF / 1.3 Mb |
LMC7211-N. www.ti.com. 5.0V and 15.0V Electrical Characteristics (continued). Boldface. Symbol. Parameter. Conditions. LMC7211AI
LMC7211-N
SNOS746F – MAY 2004 – REVISED JANUARY 2013
www.ti.com 5.0V and 15.0V Electrical Characteristics (continued)
Unless otherwise specified, all limits guaranteed for TJ = 25°C, V+ = 5.0V and 15V, V− = 0V, VCM = VO = V+/2.
Boldface
limits apply at the temperature extremes.
Symbol Parameter Conditions LMC7211AI LMC7211BI Units Typ (1) Limit(2) Limit(2)
ISC Short Circuit Current Sourcing 30 mA Sinking (3) 45 mA (3) Do not short circuit output to V+, when V+ is greater than 12V or reliability will be adversely affected.
AC Electrical Characteristics
Unless otherwise specified, all limits guaranteed for TJ = 25°C, V+ = 5V, V− = 0V, VCM = VO = V+/2.
Boldface
limits apply at the temperature extreme.
trise Rise Time f = 10 kHz, Cl = 50 pF, 0.3 μs Overdrive = 10 mV (3) tfall Fall Time f = 10 kHz, Cl = 50 pF, 0.3 μs Overdrive = 10 mV (3) tPHL Propagation Delay (High f = 10 kHz, 10 mV 10 μs to Low) (4) Cl = 50 pF (3) 100 mV 4 V+ = 2.7V, 10 mV 10 μs f = 10 kHz, 100 mV 4 Cl = 50 pF (3) tPLH Propagation Delay f = 10 kHz, 10 mV 6 μs (Low to High)(4) Cl = 50p(3) 100 mV 4 V+ = 2.7V, 10 mV 7 μs f = 10 kHz, 100 mV 4 Cl = 50 pF(3) (1) Typical values represent the most likely parametric norm. (2) All limits are guaranteed by testing or statistical analysis. (3) CL includes the probe and jig capacitance. (4) Input step voltage for propagation delay measurement is 2V. 4 Submit Documentation Feedback Copyright © 2004–2013, Texas Instruments Incorporated Product Folder Links: LMC7211-N Document Outline FEATURES Applications DESCRIPTION Connection Diagram Absolute Maximum Ratings Operating Ratings 2.7V Electrical Characteristics 5.0V and 15.0V Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Application Information Benefits of the LMC7211 Tiny Comparator Low Voltage Operation Shoot-Through Current Output Short Circuit Current Hysteresis Input Protection Layout Considerations Open Drain Output, Dual Versions Additional SOT23-5 Tiny Devices Spice Macromodel
