Datasheet LM2734 (Texas Instruments) - 6
Description | Thin SOT 1-A Load Step-Down DC-DC Regulator |
Pages / Page | 37 / 6 — LM2734. www.ti.com. 6.6 Typical Performance Characteristics. Figure 1. … |
Revision | J |
File Format / Size | PDF / 1.6 Mb |
LM2734. www.ti.com. 6.6 Typical Performance Characteristics. Figure 1. Oscillator Frequency vs Temperature - L1 = 4.7 µH
LM2734
SNVS288J – SEPTEMBER 2004 – REVISED DECEMBER 2014
www.ti.com 6.6 Typical Performance Characteristics
All curves taken at VIN = 5 V, VBOOST - VSW = 5 V and TA = 25°C, unless specified otherwise.
Figure 1. Oscillator Frequency vs Temperature - L1 = 4.7 µH Figure 2. Oscillator Frequency vs Temperature - L1 = 10 μH Figure 3. Current Limit vs Temperature Figure 4. Current Limit vs Temperature VIN = 20 V Figure 5. VFB vs Temperature Figure 6. RDSON vs Temperature
6 Submit Documentation Feedback Copyright © 2004–2014, Texas Instruments Incorporated Product Folder Links: LM2734 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Typical Performance Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Output Overvoltage Protection 7.3.2 Undervoltage Lockout 7.3.3 Current Limit 7.3.4 Thermal Shutdown 7.4 Device Functional Modes 7.4.1 Enable Pin / Shutdown Mode 7.4.2 Soft-Start 8 Application and Implementation 8.1 Application Information 8.1.1 Boost Function 8.2 Typical Applications 8.2.1 LM2734X (1.6 MHz) VBOOST Derived from VIN 5V to 1.5 V/1 A 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 8.2.2 LM2734X (1.6 MHz) VBOOST Derived from VOUT 12 V to 3.3 V /1 A 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 8.2.2.3 Application Curves 8.2.3 LM2734X (1.6 MHz) VBOOST Derived from VSHUNT 18 V to 1.5 V /1 A 8.2.3.1 Design Requirements 8.2.3.2 Detailed Design Procedure 8.2.3.3 Application Curves 8.2.4 LM2734X (1.6 MHz) VBOOST Derived from Series Zener Diode (VIN) 15 V to 1.5 V / 1 A 8.2.4.1 Design Requirements 8.2.4.2 Detailed Design Procedure 8.2.4.3 Application Curves 8.2.5 LM2734X (1.6 MHz) VBOOST Derived from Series Zener Diode (VOUT) 15 V to 9 V /1 A 8.2.5.1 Design Requirements 8.2.5.2 Detailed Design Procedure 8.2.5.3 Application Curves 8.2.6 LM2734Y (550 kHz) VBOOST Derived from VIN 5 V to 1.5 V / 1 A 8.2.6.1 Design Requirements 8.2.6.2 Detailed Design Procedure 8.2.6.3 Application Curves 8.2.7 LM2734Y (550 kHz) VBOOST Derived from VOUT 12 V to 3.3 V / 1 A 8.2.7.1 Design Requirements 8.2.7.2 Detailed Design Procedure 8.2.7.3 Application Curves 8.2.8 LM2734Y (550 kHz) VBOOST Derived from VSHUNT 18 V to 1.5 V / 1 A 8.2.8.1 Design Requirements 8.2.8.2 Detailed Design Procedure 8.2.8.3 Application Curves 8.2.9 LM2734Y (550 kHz) VBOOST Derived from Series Zener Diode (VIN) 15 V to 1.5 V / 1 A 8.2.9.1 Design Requirements 8.2.9.2 Detailed Design Procedure 8.2.9.3 Application Curves 8.2.10 LM2734Y (550 kHz) VBOOST Derived from Series Zener Diode (VOUT) 15 V to 9 V / 1 A 8.2.10.1 Design Requirements 8.2.10.2 Detailed Design Procedure 8.2.10.3 Application Curves 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Third-Party Products Disclaimer 11.2 Trademarks 11.3 Electrostatic Discharge Caution 11.4 Glossary 12 Mechanical, Packaging, and Orderable Information
