Datasheet LM119, LM219, LM319 (LMx19) (National Semiconductor) - 6
ManufacturerNational Semiconductor
DescriptionHigh Speed Dual Comparator
Pages / Page25 / 6 — LM119,. LM219,. LM319. www.ti.com. 5.5 Electrical Characteristics LM319, …
LM119,. LM219,. LM319. www.ti.com. 5.5 Electrical Characteristics LM319, LM319A. LM319A. PARAMETER. TEST CONDITIONS. UNIT. MIN. TYP. MAX
LM119, LM219, LM319 www.ti.com 5.5 Electrical Characteristics LM319, LM319A LM319A PARAMETER TEST CONDITIONS UNIT MIN TYP MAX
LM119, LM219, LM319
SNOSBJ2B – AUGUST 2000 – REVISED JANUARY 2016
These specifications apply for VS = ±15 V, and 0°C ≤ TA ≤ 70°C, unless otherwise stated. The offset voltage, offset current, and bias current specifications apply for any supply voltage from a single 5-V supply up to ±15-V supplies. Do not operate the device with more than 16 V from ground to VS.
LM319A LM319 PARAMETER TEST CONDITIONS UNIT MIN TYP MAX MIN TYP MAX
Input Offset Voltage(1) TA = 25°C, RS ≤ 5k 0.5 1 2 8 mV Input Offset Current (1) TA = 25°C 20 40 80 200 nA Input Bias Current TA = 25°C 150 500 250 1000 nA Voltage Gain TA = 25°C(2) 20 40 8 40 V/mV Response Time(3) TA = 25°C, VS = ±15 V 80 80 ns V Saturation Voltage IN ≤ −10 mV, IOUT = 25 mA 0.75 1.5 0.75 1.5 V TA = 25°C V Output Leakage Current IN ≥ 10 mV, VOUT = 35 V 0.2 10 0.2 10 µA V− = VGND = 0 V, TA = 25°C Input Offset Voltage(1) RS ≤ 5k 10 10 mV Input Offset Current (1) 300 300 nA Input Bias Current 1000 1200 nA VS = ±15 V ±13 ±13 Input Voltage Range V V+ = 5 V, V- = 0 1 3 1 3 V+ ≥ 4.5 V, V− = 0 Saturation Voltage 0.3 0.4 0.3 0.4 V VIN ≤ −10 mV, ISINK ≤ 3.2 mA Differential Input Voltage ±5 ±5 V Positive Supply Current TA = 25°C, V+ = 5 V, V− = 0 4.3 4.3 mA Positive Supply Current TA = 25°C, VS = ±15 V 8 12.5 8 12.5 mA Negative Supply Current TA = 25°C, VS = ±15 V 3 5 3 5 mA (1) The offset voltages and offset currents given are the maximum values required to drive the output within a volt of either supply with a 1- mA load. Thus, these parameters define an error band and take into account the worst case effects of voltage gain and input impedance. (2) Output is pulled up to 15 V through a 1.4-kW resistor. (3) The response time specified is for a 100-mV input step with 5-mV overdrive. 6 Submit Documentation Feedback Copyright © 2000–2016, Texas Instruments Incorporated Product Folder Links: LM119 LM219 LM319 Document Outline 1 Features 2 Description Table of Contents 3 Revision History 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Thermal Information 5.4 Electrical Characteristics LM119, LM219 5.5 Electrical Characteristics LM319, LM319A 5.6 Typical Characteristics 5.6.1 Typical Characteristics – LM119, LM119A, LM219 5.6.2 Typical Characteristics – LM319, LM319A 6 Detailed Description 6.1 Functional Block Diagram 7 Application and Implementation 7.1 Typical Applications 7.1.1 Relay Driver 7.1.2 Window Detector 8 Device and Documentation Support 8.1 Related Links 8.2 Community Resources 8.3 Trademarks 8.4 Electrostatic Discharge Caution 8.5 Glossary 9 Mechanical, Packaging, and Orderable Information
