Datasheet LF411 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionJFET-Input Operational Amplifier datasheet
Pages / Page11 / 1 — LF411. JFET-INPUT OPERATIONAL AMPLIFIER. Low Input Bias Current, 50 pA …
RevisionC
File Format / SizePDF / 393 Kb
LF411. JFET-INPUT OPERATIONAL AMPLIFIER. Low Input Bias Current, 50 pA Typ. D OR P PACKAGE. (TOP VIEW)
Datasheet LF411 Texas Instruments, Revision: C
LF411 JFET-INPUT OPERATIONAL AMPLIFIER
SLOS011C – MARCH 1987 – REVISED OCTOBER 1997 D
Low Input Bias Current, 50 pA Typ D OR P PACKAGE
D
(TOP VIEW) Low Input Noise Current, 0.01 pA/
Hz Typ
D
Low Supply Current, 2 mA Typ
BAL1 1 8 NC D
High Input impedance, 1012
Typ
IN – 2 7 VCC+ D
Low Total Harmonic Distortion
IN + 3 6 OUT D
Low 1/f Noise Corner, 50 Hz Typ
V 4 5 CC – BAL2 D
Package Options Include Plastic Small-Outline (D) and Standard (P) DIPs
NC – No internal connection
description
This device is a low-cost, high-speed, JFET-input operational amplifier with very low input offset voltage and a maximum input offset voltage drift. It requires low supply current, yet maintains a large gain-bandwidth product and a fast slew rate. In addition, the matched high-voltage JFET input provides very low input bias and offset currents. The LF411 can be used in applications such as high-speed integrators, digital-to-analog converters, sample-and-hold circuits, and many other circuits. The LF411C is characterized for operation from 0°C to 70°C. The LF411I is characterized for operation from –40°C to 85°C.
symbol 2 IN – 6 OUT 3 IN + + 1 BAL1 5 BAL2 AVAILABLE OPTIONS PACKAGE VIO V max IO TA AT 25
C SMALL OUTLINE PLASTIC DIP (D) (P)
0°C to 70°C 2 mV LF411CD LF411CP –40°C to 85°C 2 mV LF411ID LF411IP The D packages are available taped and reeled. Add the suffix R to the device type (i.e., LF411CDR). Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
PRODUCTION DATA information is current as of publication date.
Copyright 1997, Texas Instruments Incorporated
Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters.
POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1
