Datasheet OPA2333, OPA333 (Texas Instruments) - 2
ManufacturerTexas Instruments
DescriptionOPAx333 1.8-V, microPower, CMOS Operational Amplifiers, Zero-Drift
Pages / Page45 / 2 — OPA333. , OPA2333. www.ti.com. Table of Contents. Features. Application …
RevisionE
OPA333. , OPA2333. www.ti.com. Table of Contents. Features. Application and Implementation. Applications. Description. Revision History
OPA333 , OPA2333 www.ti.com Table of Contents Features Application and Implementation Applications Description Revision History
OPA333
link to page 1 link to page 15 link to page 15 link to page 1 link to page 15 link to page 1 link to page 20 link to page 2 link to page 22 link to page 3 link to page 23 link to page 5 link to page 23 link to page 5 link to page 23 link to page 5 link to page 24 link to page 5 link to page 24 link to page 6 link to page 24 link to page 6 link to page 24 link to page 7 link to page 24 link to page 8 link to page 24 link to page 12 link to page 24 link to page 12 link to page 25 link to page 12 link to page 12 link to page 25 link to page 14 link to page 1 link to page 1 link to page 1 link to page 5 link to page 8 link to page 8
OPA333 , OPA2333
SBOS351E – MARCH 2006 – REVISED DECEMBER 2015
www.ti.com Table of Contents 1 Features
.. 1
8 Application and Implementation
.. 15
2 Applications
... 1 8.1 Application Information.. 15 8.2 Typical Applications ... 15
3 Description
... 1 8.3 System Examples ... 20
4 Revision History
... 2
9 Power Supply Recommendations
.. 22
5 Pin Configuration and Functions
... 3
10 Layout
... 23
6 Specifications
... 5 10.1 Layout Guidelines ... 23 6.1 Absolute Maximum Ratings .. 5 10.2 Layout Example .. 23 6.2 ESD Ratings.. 5
11 Device and Documentation Support
... 24 6.3 Recommended Operating Conditions ... 5 11.1 Device Support.. 24 6.4 Thermal Information: OPA333 .. 6 11.2 Documentation Support .. 24 6.5 Thermal Information: OPA2333 .. 6 11.3 Related Links .. 24 6.6 Electrical Characteristics... 7 11.4 Community Resources.. 24 6.7 Typical Characteristics .. 8 11.5 Trademarks ... 24
7 Detailed Description
.. 12 11.6 Electrostatic Discharge Caution .. 24 7.1 Overview ... 12 11.7 Glossary .. 25 7.2 Functional Block Diagram ... 12
12 Mechanical, Packaging, and Orderable
7.3 Feature Description... 12
Information
... 25 7.4 Device Functional Modes.. 14
4 Revision History
NOTE: Page numbers for previous revisions may differ from page numbers in the current version.
Changes from Revision D (November 2013) to Revision E Page
• Added Pin Configuration and Functions section, ESD Ratings and Thermal Information tables, Feature Description section, Device Functional Modes, Application and Implementation section, Power Supply Recommendations section, Layout section, Device and Documentation Support section, and Mechanical, Packaging, and Orderable Information section .. 1
Changes from Revision C (May 2007) to Revision D Page
• Changed data sheet format to most current standard look and feel .. 1 • Added OPA2333 DFN-8 pinout to front page... 1 • Changed 2nd signal input terminals parameter in the Absolute Maximum Ratings from "voltage" to "current" (typo) .. 5 • Added Table 1 .. 8 2 Submit Documentation Feedback Copyright © 2006–2015, Texas Instruments Incorporated Product Folder Links: OPA333 OPA2333 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA333 6.5 Thermal Information: OPA2333 6.6 Electrical Characteristics 6.7 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Operating Voltage 7.3.2 Input Voltage 7.3.3 Internal Offset Correction 7.3.4 Achieving Output Swing to the Op Amp Negative Rail 7.3.5 DFN Package 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 High-Side Voltage-to-Current (V-I) Converter 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curve 8.2.2 Precision, Low-Level Voltage-to-Current (V-I) Converter 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 8.2.2.3 Application Curves 8.2.3 Composite Amplifier 8.2.3.1 Design Requirements 8.2.3.2 Detailed Design Procedure 8.2.3.3 Application Curve 8.3 System Examples 8.3.1 Temperature Measurement Application 8.3.2 Single Operational Amplifier Bridge Amplifier Application 8.3.3 Low-Side Current Monitor Application 8.3.4 Other Applications 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.1.1 General Layout Guidelines 10.1.2 DFN Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Related Links 11.4 Community Resources 11.5 Trademarks 11.6 Electrostatic Discharge Caution 11.7 Glossary 12 Mechanical, Packaging, and Orderable Information
