Datasheet LM556 (Texas Instruments) - 6
Manufacturer | Texas Instruments |
Description | Dual Timer |
Pages / Page | 20 / 6 — LM556. www.ti.com. 6.6 Typical Characteristics. Figure 1. Minimum Pulse … |
Revision | A |
LM556. www.ti.com. 6.6 Typical Characteristics. Figure 1. Minimum Pulse Width Required for Triggering
LM556
SNAS549A – MARCH 2000 – REVISED OCTOBER 2015
www.ti.com 6.6 Typical Characteristics
DS007852-4
Figure 1. Minimum Pulse Width Required for Triggering Figure 2. Supply Current vs Supply Voltage (Each Section) Figure 3. High Output Voltage vs Output Source Current Figure 4. Low Output Voltage vs Output Sink Current Figure 5. Low Output Voltage vs Output Sink Current Figure 6. Low Output Voltage vs Output Sink Current
6 Submit Documentation Feedback Copyright © 2000–2015, Texas Instruments Incorporated Product Folder Links: LM556 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Operating Characteristics 7.3.2 Timing from Microseconds Through Hours 7.4 Device Functional Modes 7.4.1 Monostable Mode 7.4.2 Astable (Free-Running) Mode 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curve 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Community Resources 11.3 Trademarks 11.4 Electrostatic Discharge Caution 11.5 Glossary 12 Mechanical, Packaging, and Orderable Information
