Datasheets - Current Sense Amplifiers Linear Technology - 2
Subsection: "Current Sense Amplifiers"
Manufacturer: "Linear Technology"
Search results: 67 Output: 21-40
View: List / Images
  1. Precision, Rail-to-Rail Input Current Sense Amplifier
  2. Precision, Gain Selectable High Side Current Sense Amplifier
  1. High Voltage, Bidirectional Current Sense Amplifier
  2. High Voltage, Bidirectional Current Sense Amplifier
  3. High Voltage, Bidirectional Current Sense Amplifier
  4. Precision, High Side Current Sense Amplifiers
  5. Precision, High Side Current Sense Amplifiers
  6. Current Sense Amplifier, Reference and Comparators with POR
  7. Datasheet LT1620IS8 - Linear Technology CURRENT SENSE AMP, 5  V, 0-32VO, 8SOIC
    Part Number: LT1620IS8 Manufacturer: Linear Technology Description: CURRENT SENSE AMP, 5 V, 0-32VO, 8SOIC Download Data Sheet Docket: LT1620/LT1621 Rail-to-Rail Current Sense Amplifier FEATURES s s s DESCRIPTIO s Specifications: Input Bias Current: ...
  8. Part Number: LT6108IMS8-2 Manufacturer: Linear Technology Description: CURRENT SENSE, AMP + REF + COMP, 8MSOP Specifications: Bandwidth: 1 MHz Common Mode Rejection Ratio: 125 dB Input Bias Current: 60 nA Input Offset Voltage: 350 µV Number of ...
  9. Part Number: LT6109HMS-2 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, 10MSOP Specifications: Bandwidth: 1 MHz Common Mode Rejection Ratio: 125 dB Input Bias Current: 60 nA Input Offset Voltage: 350 µV Number of Amplifiers: 1 ...
  10. Part Number: LT6109HMS-1 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, 10MSOP Specifications: Bandwidth: 1 MHz Common Mode Rejection Ratio: 125 dB Input Bias Current: 60 nA Input Offset Voltage: 350 µV Number of Amplifiers: 1 ...
  11. Datasheet LT6108HDCB-2 - Linear Technology AMP, CURRENT SENSE, 8DFN
    Part Number: LT6108HDCB-2 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, 8DFN Download Data Sheet Docket: LT6108-1/LT6108-2 High Side Current Sense Amplifier with Reference and Comparator FEATURES n DESCRIPTION The LT®6108 is a ...
  12. Datasheet LT6108HDCB-1 - Linear Technology AMP, CURRENT SENSE, 8DFN
    Part Number: LT6108HDCB-1 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, 8DFN Download Data Sheet Docket: LT6108-1/LT6108-2 High Side Current Sense Amplifier with Reference and Comparator FEATURES n DESCRIPTION The LT®6108 is a ...
  13. Datasheet LT1999IMS8-10 - Linear Technology AMP, CURRENT SENSE, 8MSOP
    Part Number: LT1999IMS8-10 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, 8MSOP Download Data Sheet Docket: LT1999-10/LT1999-20/ LT1999-50 High Voltage, Bidirectional Current Sense Amplifier FEATURES n n n n n n n n n n n ...
  14. Datasheet LT1397CDE - Linear Technology CURRENT FEEDBACK AMP, QUAD, 14DFN
    Part Number: LT1397CDE Manufacturer: Linear Technology Description: CURRENT FEEDBACK AMP, QUAD, 14DFN Download Data Sheet Docket: LT1395/LT1396/LT1397 Single/Dual/Quad 400MHz Current Feedback Amplifier FEATURES DESCRIPTIO 400MHz Bandwidth on ± 5V ...
  15. Datasheet LT1621CGN - Linear Technology IC, AMP CURRENT SENSE, SMD, SSOP16
    Part Number: LT1621CGN Manufacturer: Linear Technology Description: IC, AMP CURRENT SENSE, SMD, SSOP16 Download Data Sheet Docket: LT1620/LT1621 Rail-to-Rail Current Sense Amplifier FEATURES s s s DESCRIPTIO s Specifications: Amplifier Case Style: ...
  16. Datasheet LT1999IS8-50 - Linear Technology IC, CURR SENS AMP, 1.2 MHz, SOIC8
    Part Number: LT1999IS8-50 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 1.2 MHz, SOIC8 Specifications: Bandwidth: 1.2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output ...
  17. Datasheet LT1999IS8-20 - Linear Technology IC, CURR SENS AMP, 2 MHz, SOIC8
    Part Number: LT1999IS8-20 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, SOIC8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  18. Datasheet LT1999IS8-10 - Linear Technology IC, CURR SENS AMP, 2 MHz, SOIC8
    Part Number: LT1999IS8-10 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, SOIC8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
Sort by: relevance / date
