Datasheets - Differential Amplifiers Linear Technology - 4
Subsection: "Differential Amplifiers"
Manufacturer: "Linear Technology"
Search results: 99 Output: 61-80
View: List / Images
  1. Datasheet LTC1992-2CMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992-2CMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  2. Datasheet LT6402IUD-6 - Linear Technology AMP, DIFFERENTIAL, DC-0.3GHZ, SMD
    Part Number: LT6402IUD-6 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, DC-0.3GHZ, SMD Download Data Sheet Docket: FEATURES LT6402-6 300MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 6dB) DESCRIPTIO The ...
  1. Datasheet LT1993IUD-4 - Linear Technology AMP, DIFFERENTIAL, DC-0.9GHZ, SMD
    Part Number: LT1993IUD-4 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, DC-0.9GHZ, SMD Download Data Sheet Docket: FEATURES LT1993-4 900MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 4V/V) DESCRIPTIO The ...
  2. Datasheet LTC1992-5CMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992-5CMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  3. Datasheet LTC1992-1HMS8 - Linear Technology IC, SM, OP AMP, DIFF
    Part Number: LTC1992-1HMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, DIFF Download Data Sheet Docket: LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family FEATURES DESCRIPTIO Adjustable Gain and Fixed ...
  4. Datasheet LT6600IS8-2.5 - Linear Technology AMP, DIFFERENTIAL, 2.5 MHz LPF, SO-8
    Part Number: LT6600IS8-2.5 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, 2.5 MHz LPF, SO-8 Download Data Sheet Docket: LT6600-2.5 Very Low Noise, Differential Amplifier and 2.5MHz Lowpass Filter FEATURES s s DESCRIPTIO s s s s ...
  5. Datasheet LT6411IUD - Linear Technology AMP, DIFF ADC, DRIVER, DUAL, QFN-16
    Part Number: LT6411IUD Manufacturer: Linear Technology Description: AMP, DIFF ADC, DRIVER, DUAL, QFN-16 Download Data Sheet Docket: FEATURES LT6411 650MHz Differential ADC Driver/Dual Selectable Gain Amplifier DESCRIPTION The LT®6411 is a dual ...
  6. Datasheet LT6402IUD-12 - Linear Technology AMP, DIFFERENTIAL, DC-0.3GHZ, SMD
    Part Number: LT6402IUD-12 Manufacturer: Linear Technology Description: AMP, DIFFERENTIAL, DC-0.3GHZ, SMD Download Data Sheet Docket: FEATURES LT6402-12 300MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 12dB) DESCRIPTIO The ...
  7. Datasheet LTC6404CUD-1 - Linear Technology IC, DIFF AMP, 500 MHz, 450 V/µs, QFN-16
    Part Number: LTC6404CUD-1 Manufacturer: Linear Technology Description: IC, DIFF AMP, 500 MHz, 450 V/µs, QFN-16 Specifications: Amplifier Case Style: QFN Bandwidth: 500 MHz Gain dB Max: 1 dB Input Offset Voltage: 2 mV Number of Amplifiers: 1 Slew ...
  8. Datasheet LTC6403IUD-1 - Linear Technology AMP, DIFF, 200  MHz, 200V/US, 16QFN
    Part Number: LTC6403IUD-1 Manufacturer: Linear Technology Description: AMP, DIFF, 200 MHz, 200V/US, 16QFN Download Data Sheet Specifications: Bandwidth: 200 MHz Input Offset Voltage: 2 mV MSL: MSL 1 - Unlimited Number of Amplifiers: 1 Number of ...
  9. Datasheet LT6600CS8-15 - Linear Technology IC, DIFFERENTIAL AMP, 15 MHz, SOIC-8
    Part Number: LT6600CS8-15 Manufacturer: Linear Technology Description: IC, DIFFERENTIAL AMP, 15 MHz, SOIC-8 Download Data Sheet Specifications: Amplifier Case Style: SOIC Bandwidth: 15 MHz Input Offset Voltage: 35 mV Number of Amplifiers: 1 Number ...
  10. Datasheet LT6350CMS8 - Linear Technology OP AMP, ADC DRIVER, 115  MHz, 8MSOP
    Part Number: LT6350CMS8 Manufacturer: Linear Technology Description: OP AMP, ADC DRIVER, 115 MHz, 8MSOP Download Data Sheet Docket: FEATURES n n n n n n n n n n n n n n LT6350 Low Noise Single-Ended to Differential Converter/ADC Driver DESCRIPTION ...
  11. Datasheet LT6350CDD - Linear Technology IC, ADC DRIVER, 115 MHz, 48 V/µs, DFN-8
    Part Number: LT6350CDD Manufacturer: Linear Technology Description: IC, ADC DRIVER, 115 MHz, 48 V/µs, DFN-8 Specifications: Amplifier Case Style: DFN Bandwidth: 115 MHz Input Offset Voltage: 280 µV Number of Amplifiers: 2 Number of Pins: 8 Slew ...
  12. Datasheet LTC6601IUF-2 - Linear Technology IC, DIFF AMP, LOW POWER, 20QFN
    Part Number: LTC6601IUF-2 Manufacturer: Linear Technology Description: IC, DIFF AMP, LOW POWER, 20QFN Specifications: Amplifier Case Style: QFN Bandwidth: 27 MHz Base Number: 6601 Input Offset Voltage Max: 2 mV Input Offset Voltage: 2 mV Mounting ...
  13. Datasheet LTC6421IUDC-20 - Linear Technology DIFF AMP/ADC DRIVER, 1.3GHZ, 20DFN
    Part Number: LTC6421IUDC-20 Manufacturer: Linear Technology Description: DIFF AMP/ADC DRIVER, 1.3GHZ, 20DFN Download Data Sheet Docket: FEATURES n n n n n n n n n n n n n n LTC6421-20 Dual Matched 1.3GHz Differential Amplifiers/ADC Drivers ...
  14. Datasheet LTC6421CUDC-20 - Linear Technology DIFF AMP/ADC DRIVER, 1.3GHZ, 20DFN
    Part Number: LTC6421CUDC-20 Manufacturer: Linear Technology Description: DIFF AMP/ADC DRIVER, 1.3GHZ, 20DFN Download Data Sheet Docket: FEATURES n n n n n n n n n n n n n n LTC6421-20 Dual Matched 1.3GHz Differential Amplifiers/ADC Drivers ...
  15. Datasheet LTC6420IUDC-20 - Linear Technology IC, DIFF AMP, DUAL, 1.8GHZ, 20QFN
    Part Number: LTC6420IUDC-20 Manufacturer: Linear Technology Description: IC, DIFF AMP, DUAL, 1.8GHZ, 20QFN Download Data Sheet Docket: FEATURES n n n n n n n n n n n n n n LTC6420-20 Dual Matched 1.8GHz Differential Amplifiers/ADC Drivers ...
  16. Datasheet LTC6420CUDC-20 - Linear Technology IC, DIFF AMP, 1.8  GHz, 4500  V/µs, QFN-20
    Part Number: LTC6420CUDC-20 Manufacturer: Linear Technology Description: IC, DIFF AMP, 1.8 GHz, 4500 V/µs, QFN-20 Download Data Sheet Docket: FEATURES n n n n n n n n n n n n n n LTC6420-20 Dual Matched 1.8GHz Differential Amplifiers/ADC Drivers ...
  17. Datasheet LTC6405IUD - Linear Technology DIFF AMP, 5 V, 2.7GHZ, R/R, 16QFN
    Part Number: LTC6405IUD Manufacturer: Linear Technology Description: DIFF AMP, 5 V, 2.7GHZ, R/R, 16QFN Download Data Sheet Specifications: Amplifier Case Style: QFN Bandwidth: 2.7GHz Base Number: 6405 Gain dB Max: 1 dB Input Offset Voltage Max: 7 ...
  18. Datasheet LTC6405IMS8E - Linear Technology IC, DIFF AMP< 2.7GHZ, 5 V, LN, 8MSOP
    Part Number: LTC6405IMS8E Manufacturer: Linear Technology Description: IC, DIFF AMP< 2.7GHZ, 5 V, LN, 8MSOP Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 2.7GHz Base Number: 6405 Gain dB Max: 1 dB Input Offset Voltage ...
Sort by: relevance / date
