R&S®RTE Tools such as QuickMeas, fast mask tests, powerful spec- trum analysis, history function and 77 automatic measure- Oscilloscope ment functions are supplied as standard. Results are avail- able fast thanks to hardware-assisted implementation of the measurement tools in the Rohde & Schwarz ASIC. The At a glance results are based on a large number of waveforms to pro- vide statistically conclusive information. R&S®RTE oscilloscopes support dedicated application so- lutions for complex analyses, including trigger and decod- Truly uncompromised in performance and ing options for serial protocols and a power analysis op- impressively user-friendly – that’s the R&S®RTE tion. The mixed signal option provides 16 digital channels oscilloscope. for analyzing logical components in embedded designs. The powerful R&S®RTE is impressively easy to use thanks With bandwidths from 200 MHz to 2 GHz and top perfor- to its high-resolution 10.4" XGA touchscreen. mance parameters, the R&S®RTE oscilloscopes set stan- dards in their class: R&S®RTE oscilloscopes offer a fully integrated multi- ❙Highest sampling rate of 5 Gsample/s and deepest domain test solution with time, frequency, protocol and memory of 200 Msample for accurate acquisition of long logic analysis functions. This one-box solution makes it signal sequences possible to quickly detect errors even in complex designs. ❙Acquisition rate of more than one million waveforms/s for finding signal faults quickly From embedded design development to power electronics ❙Extremely low-noise frontends and 16-bit vertical analysis to general debugging, the R&S®RTE oscilloscopes resolution in high definition mode for precise results handle everyday T&M challenges quickly, accurately and ❙Highly accurate digital trigger system with virtually no easily. jitter for triggering on smallest signal details in realtime 2 RTE_bro_en_3606-9033-12_v1400.indd 2 11.06.2018 14:09:33
