Datasheet DS-2CD2420F-I(W) (Hikvision) - 3
Manufacturer | Hikvision |
Description | 2 Megapixel CMOS Alarm Pro Cube Camera |
Pages / Page | 4 / 3 — Order Models |
File Format / Size | PDF / 479 Kb |
Order Models
Standard ONVIF, PSIA, CGI, ISAPI Interface Communication 1 RJ45 10M/100M Ethernet interface Interface Alarm input 1 Alarm output 1 Wi-Fi Specification(Only for the products with Wi-Fi module built-in) Wireless Standards IEEE802.11b, 802.11g, 802.11n Frequency Range 2.4 GHz ~ 2.4835 GHz Channel Bandwidth 20/40MHz Support 802.11b: CCK, QPSK, BPSK Protocols 802.11g/n: OFDM Security 64/128-bit WEP, WPA/WPA2, WPA-PSK/WPA2-PSK, WPS 11b: 17±1.5dBm @ 11Mbps Transmit Output 11g: 14±1.5dBm @ 54Mbps Power 11n: 12.5±1.5dBm 11b: -90dBm @ 11Mbps (Typical) Receive Sensitivity 11g: -75dBm @ 54Mpbs (Typical) 11n: -74dBm (Typical) 11b: 11Mbps Transfer Rates 11g: 54Mbps 11n: up to 150Mbps Wireless Range 50m(depend on environment) Wireless Standards IEEE802.11b, 802.11g, 802.11n General Operating -30 °C – 60 °C (-22 °F – 140 °F) Conditions Humidity 95% or less (non-condensing) Power Supply DC12V/PoE(802.3af) Power MAX. 4.5W Consumption Angle: 80° PIR Range: 10m IR Range 10 meters Dimensions (mm) 72.3×89.9×131.3 Weight 400g(0.88lbs) * “-W” series support Wi-Fi (802.11b/g/n) and the modules with Wi-Fi function don’t support the 802.1X protocol. *Without power adaptor in the case by default.
Order Models
DS-2CD2420F-I, DS-2CD2420F-IW ©2006 – 2014 by HIKVISION. All rights reserved. 3
