Datasheet ADA4522-1, ADA4522-2, ADA4522-4 (Analog Devices) - 2
DescriptionSingle 55 V, EMI Enhanced, Zero-Drift, Ultralow Noise, Rail-to-Rail Output Operational Amplifiers
Pages / Page32 / 2 — ADA4522-1/ADA4522-2/ADA4522-4. Data Sheet. TABLE OF CONTENTS. REVISION …
RevisionF
ADA4522-1/ADA4522-2/ADA4522-4. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 10/2016—Rev. D to Rev. E
ADA4522-1/ADA4522-2/ADA4522-4 Data Sheet TABLE OF CONTENTS REVISION HISTORY 10/2016—Rev D to Rev E
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 4 link to page 5 link to page 7 link to page 7 link to page 7 link to page 8 link to page 10 link to page 21 link to page 22 link to page 22 link to page 22 link to page 23 link to page 23 link to page 24 link to page 25 link to page 25 link to page 27 link to page 27 link to page 27 link to page 27 link to page 28 link to page 28 link to page 29 link to page 30 link to page 32
Features .. 1 Input Protection ... 22 Applications ... 1 Single-Supply and Rail-to-Rail Output ... 23 General Description ... 1 Large Signal Transient Response .. 23 Pin Connection Diagram .. 1 Noise Considerations ... 24 Revision History ... 2 EMI Rejection Ratio .. 25 Specifications ... 3 Capacitive Load Stability ... 25 Electrical Characteristics—5.0 V Operation .. 3 Applications Information .. 27 Electrical Characteristics—30 V Operation ... 4 Single-Supply Instrumentation Amplifier .. 27 Electrical Characteristics—55 V Operation ... 5 Load Cel /Strain Gage Sensor Signal Conditioning Using the Absolute Maximum Ratings .. 7 ADA4522-2 .. 27 Thermal Resistance .. 7 Precision Low-Side Current Shunt Sensor.. 28 ESD Caution .. 7 Printed Circuit Board Layout ... 28 Pin Configurations and Function Descriptions ... 8 Comparator Operation .. 29 Typical Performance Characteristics ... 10 Outline Dimensions ... 30 Theory of Operation .. 21 Ordering Guide .. 32 On-Chip Input EMI Filter and Clamp Circuit ... 22 Thermal Shutdown ... 22
REVISION HISTORY 10/2016—Rev. D to Rev. E 10/2015—Rev. 0 to Rev. A
Changes to Figure 73 .. 23 Added ADA4522-4 ... Universal
Changes to General Description Section ... 1
4/2016—Rev. C to Rev. D
Change to Common-Mode Rejection Ratio Parameter, Table 2 ... 3 Changed ADA4522-4 Pin 4 to V+ .. Throughout Change to Offset Voltage Drift Parameter, Table 3 ... 4 Changed ADA4522-4 Pin 11 to V− .. Throughout Change to Offset Voltage Drift Parameter and Input Offset Changes to Figure 5 and Table 9 ... 9 Current Parameter, Table 4 .. 5 Changes to Table 6 ... 7
2/2016—Rev. B to Rev. C
Added Figure 4 and Table 8; Renumbered Sequentially .. 8 Added ADA4522-1 ... Universal Changes to Figure 34 .. 13 Changes to Common-Mode Rejection Ratio Parameter and Changes to Figure 67 .. 19 Supply Current per Amplifier Parameter, Table 2 .. 3 Changes to Applications Information Section ... 20 Changes to Offset Voltage Drift Parameter, and Supply Current Changes to Thermal Shutdown Section .. 21 per Amplifier Parameter, Table 3 .. 4 Changes to Single-Supply Instrumentation Amplifier Section .. . 25 Changes to Offset Voltage Drift Parameter, Input Offset Current Changes to Precision Low-Side Current Shunt Sensor Section .. 27 Parameter, and Supply Current per Amplifier Parameter, Changes to Printed Circuit Board Layout Section . ... .. ... ... ... ... 28 Table 4 .. 5 Added Figure 89 and Figure 90; Outline Dimensions ... 30 Added Figure 3 and Table 7; Renumbered Sequential y ... 8 Changes to Ordering Guide .. 30 Moved Theory of Operation Section ... 21 Changes to Figure 71 .. 21
5/2015—Revision 0: Initial Version
Changes to Figure 72 .. 22
Changes to Ordering Guide .. 32
1/2016—Rev. A to Rev. B
Updated Outline Dimensions ... 29
Rev. E | Page 2 of 32 Document Outline Features Applications General Description Pin Connection Diagram Revision History Specifications Electrical Characteristics—5.0 V Operation Electrical Characteristics—30 V Operation Electrical Characteristics—55 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation On-Chip Input EMI Filter and Clamp Circuit Thermal Shutdown Input Protection Single-Supply and Rail-to-Rail Output Large Signal Transient Response Case 1 Case 2 Noise Considerations 1/f Noise Source Resistance Residual Ripple Current Noise Density EMI Rejection Ratio Capacitive Load Stability Applications Information Single-Supply Instrumentation Amplifier Load Cell/Strain Gage Sensor Signal Conditioning Using the ADA4522-2 Precision Low-Side Current Shunt Sensor Printed Circuit Board Layout Comparator Operation Outline Dimensions Ordering Guide
