DatasheetsDatasheet ADA4807-1, ADA4807-2, ADA4807-4 …
Datasheet ADA4807-1, ADA4807-2, ADA4807-4 (Analog Devices)
Description | 3.1 nV/√Hz, 1 mA, 180 MHz, Rail-to-Rail Input/Output Amplifier |
Pages / Page | 33 / 1 — 3.1 nV/√Hz, 1 mA, 180 MHz,. Rail-to-Rail Input/Output Amplifiers. Data … |
Revision | B |
File Format / Size | PDF / 759 Kb |
3.1 nV/√Hz, 1 mA, 180 MHz,. Rail-to-Rail Input/Output Amplifiers. Data Sheet. ADA4807-1/. ADA4807-2/. ADA4807-4. FEATURES
3.1 nV/√Hz, 1 mA, 180 MHz, Rail-to-Rail Input/Output Amplifiers Data Sheet ADA4807-1/ ADA4807-2/ ADA4807-4 FEATURES PIN CONNECTION DIAGRAMS Low input noise VOUT 1 6 +VS 3.1 nV/√Hz at f = 100 kHz with 29 Hz 1/f corner 0.7 pA/√Hz at f = 100 kHz with 2 kHz 1/f corner –VS 2 5 DISABLE High speed performance with dc precision
1 -00
180 MHz, −3 dB bandwidth (G = +1, V +IN 3 4 –IN
1 1
OUT = 20 mV p-p)
6 12
225 V/μs slew rate for 5 V step (rise)
Figure 1. 6-Lead SC70 and 6-Lead SOT-23 Pin Configuration (ADA4807-1)
47 ns settling time to 0.1% for 4 V step V 8 +V ±125 μV and 3.7 μV/°C maximum input offset voltage and drift OUT1 1 S –IN1 2 7 VOUT2 100 nA and 250 pA/°C maximum input offset current and drift +IN1 3 6 –IN2 Low distortion (HD2/HD3), V
058
S = ±5 V, VOUT = 2 V p-p –V
1-
S 4 5 +IN2
1 6
−141 dBc/−144 dBc at 1 kHz
12 Figure 2. 8-Lead MSOP Pin Configuration (ADA4807-2)
−112 dBc/−115 dBc at 100 kHz −95 dBc/−79 dBc at 1 MHz V 1 OUT1 10 +VS Low power operation –IN1 2 9 VOUT2 +IN1 3 8 –IN2 1.0 mA quiescent supply current per amplifier at ±5 V –V 4 S 7 +IN2
059
Dynamic power scaling DISABLE1 5 6 DISABLE2
12611-
Fully specified at +3 V, +5 V, and ±5 V supplies
Figure 3. 10-Lead LFCSP Pin Configuration (ADA4807-2)
Rail-to-rail inputs and outputs APPLICATIONS V 14 V OUT1 1 OUT4 –IN1 2 13 –IN4 High resolution analog-to-digital converter (ADC) drivers +IN1 3 12 +IN4 Portable and battery-powered instruments and systems +V 4 11 ADA4807-4 –V High component density data acquisition systems S S +IN2 5 10 +IN3 Audio signal conditioning –IN2 6 9 –IN3 Active filters
4
V
-10
OUT2 7 8 VOUT3
1 61 12 Figure 4. 14-Lead TSSOP Pin Configuration (ADA4807-4)
GENERAL DESCRIPTION
The ADA4807-1 (single), ADA4807-2 (dual), and ADA4807-4 These amplifiers are fully specified at +3 V, +5 V, and ±5 V supplies (quad) are low noise, rail-to-rail input and output, voltage and can operate over the industrial −40°C to +125°C feedback amplifiers. These amplifiers combine low power, low temperature range. noise, high speed, and dc precision to provide an attractive The ADA4807-1 is available in 6-lead SOT-23 and space-saving solution for a wide range of applications from high resolution 6-lead SC70 packages. The ADA4807-2 is available in an 8-lead data acquisition instrumentation to high performance battery- MSOP and a compact, 3 mm × 3 mm, 10-lead LFCSP. The powered and high component density systems where power ADA4807-4 is available in a 14-lead TSSOP package. consumption is of key importance. With only 1.0 mA of supply current per amplifier, the ADA4807-1/
Table 1. Other Rail-to-Rail Amplifiers
ADA4807-2/ADA4807-4 feature the lowest input voltage noise
Slew Voltage Max. Bandwidth Rate Noise V
among high speed, rail-to-rail input/output amplifiers in the
OS Device (MHz) (V/μs) (nV/√Hz) (mV)
industry and offer a wide bandwidth, high slew rate, fast settling AD8031/AD8032 80 35 15 ±1.5 time, and excellent distortion performance. Additionally, these AD8027/AD8028 190 90 4.3 0.8 amplifiers offer very low input offset voltage and drift performance, AD8029/AD8030/ 125 62 16.5 5 making them ideal for driving multiplexed and high throughput AD8040 precision 16-/18-bit successive approximation registers (SARs) and 24-bit - ADCs.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAMS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ±5 V SUPPLY 5 V SUPPLY 3 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS FREQUENCY RESPONSE FREQUENCY AND SUPPLY CURRENT DC AND INPUT COMMON-MODE PERFORMANCE SLEW, TRANSIENT, SETTLING TIME, AND CROSSTALK DISTORTION AND NOISE OUTPUT CHARACTERISTICS OVERDRIVE RECOVERY AND TURN ON/TURN OFF TIMES THEORY OF OPERATION DISABLE CIRCUITRY INPUT PROTECTION NOISE CONSIDERATIONS APPLICATIONS INFORMATION CAPACITIVE LOAD DRIVE LOW NOISE FET OPERATIONAL AMPLIFIER POWER MODE ADC DRIVER ADC DRIVING ADC DRIVING WITH DYNAMIC POWER SCALING LAYOUT, GROUNDING, AND BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
