Datasheet ADA4350 (Analog Devices) - 5
DescriptionFET Input Analog Front End with ADC Driver
Pages / Page38 / 5 — ADA4350. Data Sheet. ±5 V FET INPUT AMPLIFIER. Table 2. Parameter. Test …
File Format / SizePDF / 813 Kb
ADA4350. Data Sheet. ±5 V FET INPUT AMPLIFIER. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADA4350 Data Sheet ±5 V FET INPUT AMPLIFIER Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
TA = 25°C, +VS = +5 V, −VS = −5 V, RL = 1 kΩ, unless otherwise specified.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = −5, VOUT = 100 mV p-p 26 MHz G = −5, VOUT = 2 V p-p 24 MHz Gain Bandwidth Product 175 MHz Slew Rate VOUT = 2 V step, 10% to 90% 100 V/µs Settling Time to 0.1% G = −5, VOUT = 2 V step 28 ns NOISE/HARMONIC PERFORMANCE Harmonic Distortion (HD2/HD3) f = 100 kHz, VOUT = 2 V p-p, G = −5 −106/−114 dBc f = 1 MHz, VOUT = 2 V p-p, G = −5 −83/−93 dBc Input Voltage Noise f = 10 Hz 85 nV/√Hz f = 100 kHz 5 nV/√Hz DC PERFORMANCE Input Offset Voltage 15 80 µV Input Offset Voltage Drift From −40°C to +85°C 0.1 1.6 µV/°C From 25°C to 85°C 0.1 1.0 µV/°C Input Bias Current At 25°C ±0.25 ±1 pA At 85°C ±8 ±25 pA Input Bias Offset Current At 25°C ±0.1 ±0.8 pA At 85°C ±0.5 pA Open-Loop Gain VOUT = ±2 V 106 115 dB INPUT CHARACTERISTICS Input Resistance Common mode 100 GΩ Input Capacitance Common mode 2 pF Differential mode 3 pF Input Common-Mode Voltage Range CMRR > 80 dB −4.5 +3.8 V CMRR > 68 dB −5 +3.9 V Common-Mode Rejection Ratio VCM = ±3 V 92 115 V OUTPUT CHARACTERISTICS Output Overdrive Recovery Time VOUT = VS ± 10% 60 ns Output Voltage Swing G = +21, RF = 1 kΩ, RL open measured at FBx −3.6 to +3.9 −4.05 to +4.07 V G = +21, RF = 100 kΩ, RL open measured at FBx −4.7 to +4.8 −4.9 to +4.86 V Linear Output Current VOUT = 2 V p-p, 60 dB SFDR 18 mA rms Short-Circuit Current Sinking/sourcing 41/45 mA POWER SUPPLY Operating Range 3.3 12 V Positive Power Supply Rejection Ratio 90 109 dB Negative Power Supply Rejection Ratio 90 109 dB Rev. B | Page 4 of 37 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ±5 V FULL SYSTEM ±5 V FET INPUT AMPLIFIER ±5 V INTERNAL SWITCHING NETWORK AND DIGITAL PINS ±5 V ADC DRIVER 5 V FULL SYSTEM 5 V FET INPUT AMPLIFIER 5 V INTERNAL SWITCHING NETWORK AND DIGITAL PINS 5 V ADC DRIVER TIMING SPECIFICATIONS Timing Diagrams for Serial Mode ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISITICS FULL SYSTEM FET INPUT AMPLIFIER ADC DRIVER TEST CIRCUITS THEORY OF OPERATION KELVIN SWITCHING TECHNIQUES APPLICATIONS INFORMATION CONFIGURING THE ADA4350 SELECTING THE TRANSIMPEDANCE GAIN PATHS MANUALLY OR THROUGH THE PARALLEL INTERFACE SELECTING THE TRANSIMPEDANCE GAIN PATHS THROUGH THE SPI INTERFACE (SERIAL MODE) SPICE MODEL TRANSIMPEDANCE AMPLIFIER DESIGN THEORY TRANSIMPEDANCE GAIN AMPLIFIER PERFORMANCE THE EFFECT OF LOW FEEDBACK RESISTOR RFx USING THE T NETWORK TO IMPLEMENT LARGE FEEDBACK RESISTOR VALUES OUTLINE DIMENSIONS ORDERING GUIDE
