Data SheetADA4084-1/ADA4084-2/ADA4084-4REVISION HISTORY 8/15—Rev. G to Rev. H Added 5-Lead SOT-23 ... Universal 11/13—Rev. C to Rev. D Changes to Pin Connection Diagram Section, Figure 1, and Added 14-Lead TSSOP and 16-Lead LFCSP Packages ... Universal General Description Section .. 1 Added ADA4084-4 ... Universal Deleted Figure 3; Renumbered Sequentially ... 1 Change to Features Section and Applications Section ... 1 Changes to Large Signal Voltage Gain Parameter, Table 2 .. 4 Added Figure 2 and Figure 3; Renumbered Sequentially .. 1 Changes to Large Signal Voltage Gain Parameter, Table 3 .. 5 Changes to Table 2 .. 3 Changes to Large Signal Voltage Gain Parameter, Table 4 .. 6 Changes to Table 3 .. 4 Changes to Table 6 .. 7 Changes to Table 4 .. 5 Moved Figure 3 .. 8 Changes to Table 5 and Table 6 ... 6 Added Pin Configurations and Function Descriptions Section, Changes to Typical Performance Characteristics Section ... 7 Figure 4, Figure 5, Table 7, Table 8, and Table 9; Renumbered Updated Outline Dimensions .. 27 Sequentially .. 8 Changes to Ordering Guide ... 28 Added Figure 6, Figure 7, Figure 8, Table 10, and Table 11 ... 9 Moved Figure 9 .. 10 4/13—Rev. B to Rev. C Added Table 12 .. 10 Changes to Figure 48 Caption ... 15 Added Figure 11 and Figure 15 ... 11 Updated Outline Dimensions .. 25 Added Figure 42 and Figure 46 ... 17 Added Figure 73 and Figure 77 ... 23 6/12—Rev. A to Rev. B Updated Outline Dimensions .. 32 Added LFCSP Package .. Universal Changes to Ordering Guide ... 35 Changes to Figure 1 .. 1 Changes to Output Voltage High Parameter, Table 4 ... 5 6/15—Rev. F to Rev. G Added Figure 5 and Figure 7, Renumbered Sequentially .. 7 Changes to Figure 96 and Figure 97 ... 24 Added Figure 30 and Figure 32 ... 12 Added Figure 55 and Figure 57 ... 17 1/15—Rev. E to Rev. F Added Startup Characteristics Section .. 23 Moved Revision History ... 3 Moved Figure 78 .. 23 Changes to Table 5 .. 7 Changes to Output Phase Reversal Section and Comparator Changes to Ordering Guide ... 29 Operation Section ... 24 Updated Outline Dimensions .. 25 7/14—Rev. D to Rev. E Changes to Ordering Guide ... 26 Added ADA4084-1 .. Universal Added Figure 1; Renumbered Sequentially ... 1 2/12—Rev. 0 to Rev. A Changes to Output Voltage High Parameter, Table 2 ... 3 Changes to Data Sheet Title ... 1 Changes to Current Noise Density Parameter, Table 3 .. 4 Changes to Voltage Range in General Description .. 1 Changes to Current Noise Density Parameter, Table 4 .. 5 Changes to Supply Current/Amplifier Parameter, Table 2 .. 3 Changes to Figure 8 Caption, and Figure 9 to Figure 11 ... 7 Changes to Common-Mode Rejection Ratio Parameter, Table 3 .. 4 Changes to Figure 13 .. 8 Changes to Common-Mode Rejection Ratio Parameter, Table 4 .. 5 Changes to Figure 21 .. 9 Changes to Figure 2 .. 6 Added Figure 31; Renumbered Sequentially ... 11 Changes to Figure 24 .. 10 Changes to Figure 30 Caption, and Figure 32 to Figure 34 ... 11 Changes to Figure 32 .. 12 Changes to Figure 36 Caption to Figure 39 Caption .. 12 Changes to Figure 47 .. 14 Changes to Figure 50 .. 14 Changes to Figure 55 .. 16 Added Figure 60 .. 16 Changes to Figure 62 .. 17 Changes to Figure 59 Caption, Figure 62, and Figure 63 ... 16 Changes to Figure 73 .. 20 Changes to Figure 65 Caption to Figure 68 Caption .. 17 Changes to Figure 79 .. 19 10/11—Revision 0: Initial Version Added Figure 89 .. 21 Changes to Figure 88 Caption, Figure 91 Caption, and
Figure 92 Caption .. 21
Rev. H | Page 3 of 35 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION START-UP CHARACTERISTICS INPUT PROTECTION OUTPUT PHASE REVERSAL DESIGNING LOW NOISE CIRCUITS IN SINGLE-SUPPLY APPLICATIONS COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
