Datasheet AD713 (Analog Devices) - 5
DescriptionPrecision, High Speed, BiFET Quad Op Amp
Pages / Page21 / 5 — AD713. AD713J/AD713A. Parameter Test. Conditions/Comments. Min. Typ. Max. …
RevisionC
File Format / SizePDF / 387 Kb
AD713. AD713J/AD713A. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
AD713 AD713J/AD713A Parameter Test Conditions/Comments Min Typ Max Unit
OUTPUT CHARACTERISTICS Voltage RL ≥ 2 kΩ +13/−12.5 +13.9/−13.3 V TMIN to TMAX ±12 +13.8/−13.1 V Current Short circuit 25 mA POWER SUPPLY Rated Performance ±15 V Operating Range ±4.5 ±18 V Quiescent Current 10.0 13.5 mA TRANSISTOR COUNT Number of transistors 120 1 Input offset voltage specifications are guaranteed after 5 minutes of operation at TA = 25°C. 2 Bias current specifications are guaranteed maximum at either input after 5 minutes of operation at TA = 25°C. For higher temperatures, the current doubles every 10°C. 3 Defined as the voltage between inputs, such that neither exceeds ±10 V from ground. 4 Typically exceeding −14.1 V negative common-mode voltage on either input results in an output phase reversal. Rev. F | Page 4 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION MEASURING AD713 SETTLING TIME POWER SUPPLY BYPASSING A HIGH SPEED INSTRUMENTATION AMPLIFIER CIRCUIT A HIGH SPEED 4-OP-AMP CASCADED AMPLIFIER CIRCUIT HIGH SPEED OP AMP APPLICATIONS AND TECHNIQUES DAC Buffers (I-to-V Converters) Driving the Analog Input of an Analog-to-Digital Converter Driving A Large Capacitive Load CMOS DAC APPLICATIONS FILTER APPLICATIONS A Programmable State Variable Filter GIC AND FDNR FILTER APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
