Datasheet AD744 (Analog Devices) - 2
DescriptionPrecision, 500 ns Settling BiFET Op Amp
Pages / Page13 / 2 — AD744* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionD
File Format / SizePDF / 511 Kb
AD744* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
AD744* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
EVALUATION KITS
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth • Universal Evaluation Board for Single High Speed • MT-047: Op Amp Noise Operational Amplifiers • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Noise, and Equivalent Noise Bandwidth
DOCUMENTATION
• MT-049: Op Amp Total Output Noise Calculations for
Application Notes
Single-Pole System • AN-232: Bootstrapped IC Substrate Lowers Distortion in • MT-050: Op Amp Total Output Noise Calculations for JFET Op Amps Second-Order System • AN-348: Avoiding Passive-Component Pitfalls • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-402: Replacing Output Clamping Op Amps with Input • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Clamping Amps SFDR, MTPR • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-056: High Speed Voltage Feedback Op Amps Design Constraints in Low Voltage High Speed Systems • MT-058: Effects of Feedback Capacitance on VFB and CFB • AN-581: Biasing and Decoupling Op Amps in Single Op Amps Supply Applications • MT-059: Compensating for the Effects of Input
Data Sheet
Capacitance on VFB and CFB Op Amps Used in Current-to- • AD744: Precision, 500 ns Settling BiFET Op Amp Data Voltage Converters Sheet • MT-060: Choosing Between Voltage Feedback and
User Guides
Current Feedback Op Amps • UG-135: Evaluation Board for Single, High Speed Operational Amplifiers (8-Lead SOIC and Exposed Paddle)
DESIGN RESOURCES
• AD744 Material Declaration
TOOLS AND SIMULATIONS
• PCN-PDN Information • Analog Filter Wizard • Quality And Reliability • Analog Photodiode Wizard • Symbols and Footprints • Power Dissipation vs Die Temp • VRMS/dBm/dBu/dBV calculators
DISCUSSIONS
• AD744 SPICE Macro-Model View all AD744 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
