Datasheet AD746 (Analog Devices) - 2
DescriptionDual Precision, 500 ns Settling, BiFET Op Amp
Pages / Page9 / 2 — AD746* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 470 Kb
AD746* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
AD746* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
EVALUATION KITS
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth • Universal Evaluation Board for Dual High Speed • MT-047: Op Amp Noise Operational Amplifiers • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Noise, and Equivalent Noise Bandwidth
DOCUMENTATION
• MT-049: Op Amp Total Output Noise Calculations for
Application Notes
Single-Pole System • AN-402: Replacing Output Clamping Op Amps with Input • MT-050: Op Amp Total Output Noise Calculations for Clamping Amps Second-Order System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-052: Op Amp Noise Figure: Don't Be Misled Design Constraints in Low Voltage High Speed Systems • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-581: Biasing and Decoupling Op Amps in Single SFDR, MTPR Supply Applications • MT-056: High Speed Voltage Feedback Op Amps
Data Sheet
• MT-058: Effects of Feedback Capacitance on VFB and CFB • AD746: Dual Precision, 500 ns Settling, BiFET Op Amp Op Amps Data Sheet • MT-059: Compensating for the Effects of Input
User Guides
Capacitance on VFB and CFB Op Amps Used in Current-to- • UG-128: Universal Evaluation Board for Dual High Speed Voltage Converters Op Amps in SOIC Packages • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
TOOLS AND SIMULATIONS DESIGN RESOURCES
• Analog Filter Wizard • Analog Photodiode Wizard • AD746 Material Declaration • Power Dissipation vs Die Temp • PCN-PDN Information • VRMS/dBm/dBu/dBV calculators • Quality And Reliability • AD746 SPICE Macro-Model • Symbols and Footprints
DISCUSSIONS
View all AD746 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
