Datasheet MCP6L71, MCP6L71R, MCP6L72, MCP6L74 (Microchip) - 8
ManufacturerMicrochip
DescriptionThe MCP6L71 operational amplifier has 2MHz Gain Bandwidth Product and a low 150uA per amplifier quiescent current
Pages / Page32 / 8 — MCP6L71/1R/2/4. Note:. ) 1.E-02. 10m. (A 1.E-03. = 5.0V. VDD. d 1.E-04. …
File Format / SizePDF / 464 Kb
MCP6L71/1R/2/4. Note:. ) 1.E-02. 10m. (A 1.E-03. = 5.0V. VDD. d 1.E-04. 100µ. G = +2 V/V. itu. 1.E-05. 10µ. 1.E-06. lt o. 1.E-0. 10 7. t M. t V. n e 1.E-08
MCP6L71/1R/2/4 Note: ) 1.E-02 10m (A 1.E-03 = 5.0V VDD d 1.E-04 100µ G = +2 V/V itu 1.E-05 10µ 1.E-06 lt o 1.E-0 10 7 t M t V n e 1.E-08
Unless otherwise indicated, T ≈ A = +25°C, VDD = 5.0V, VSS = GND, VCM = VDD/2, VOUT VDD/2, VL = VDD/2, RL = 10 kΩ to VL and CL = 60 pF.
) 1.E-02 10m 6 (A 1.E-03 1m = 5.0V e ) VDD d 1.E-04 100µ V 5 ( G = +2 V/V itu e 1.E-05 10µ 4 gn ag 1.E-06 a lt o 1.E-0 10 7 3 t M 0n t V n e 1.E-08 10n u rr +125°C tp 2 u 1.E-09 1n u +85°C V t C 1.E-1 10 0 0p IN +25°C 1 t, O u V 1.E-11 10p -40°C p OUT Inpu 0 1.E-12 1p In -1.0 -0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1 0.0 -1 Input Voltage (V) Time (1 ms/div) FIGURE 2-7:
Input Current vs. Input
FIGURE 2-10:
The MCP6L71/1R/2/4 Show Voltage. No Phase Reversal.
120 0 250 ) 100 B -30 (°) t 200 n (d e 80 -60 ) in as rre Phase h u ier 60 lif 150 Ga -90 P p p t C p o 40 o o -120 o en /am T = +125°C 100 A -L Gain -L sc A T = +85°C n 20 n ie A e -150 e u p T Q A = +25°C Op 0 -180 O 50 T = -40°C A -20 -210 1 0 3 0 0. -01 1 0 1 01 0 1 02 00 0 1k 10 04k 1 05 00k 1 06 M 10 07M + + + 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 E + + E E+ E E+ 1. 1. 1.E Fr 1. eque 1.ncy ( 1.EHz) 1. 1.E+ 1.E Power Supply Voltage (V) FIGURE 2-8:
Open-Loop Gain, Phase vs.
FIGURE 2-11:
Quiescent Current vs. Frequency. Supply Voltage.
1,000 35 t y n it s 30 n rre e 25 e D it Cu ) u ag 20 lt Hz 100 irc A) /
TA = +125°C Vo V t-C 15 (m e (n or TA = +85°C is h o 10 T = +25°C A t N TA = -40°C u tut S 5 p p u In 10 O 0 0.1 1 10 100 1k 10k 100k 1M 1.E- 1.E+0 1.E+0 1.E+0 1.E+0 1.E+0 1.E+0 1.E+0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 01 0 1 Fre 2 quenc 3 y (Hz) 4 5 6 Power Supply Voltage (V) FIGURE 2-9:
Input Noise Voltage Density
FIGURE 2-12:
Output Short Circuit Current vs. Frequency. vs. Supply Voltage. DS22145A-page 8 © 2009 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications (Continued) TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuits FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 2.0V. FIGURE 2-2: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Output Voltage. FIGURE 2-4: Input Common Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Input Current vs. Input Voltage. FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L71/1R/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom vs. Output Current Magnitude. FIGURE 2-14: Large Signal Non-inverting Pulse Response. FIGURE 2-15: Small Signal Non-inverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Maximum Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table for Single Op Amps TABLE 3-2: Pin Function Table for Dual and Quad Op Amps 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Rail-to-Rail Inputs FIGURE 4-1: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-2: Output Resistor, RISO Stabilizes Large Capacitive Loads. 4.4 Supply Bypass 4.5 Unused Amplifiers FIGURE 4-3: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-4: Example Guard Ring Layout. 4.7 Application Circuits FIGURE 4-5: Inverting Integrator. 5.0 Design Tools 5.1 FilterLab® Software 5.2 MAPS (Microchip Advanced Part Selector) 5.3 Analog Demonstration and Evaluation Boards 5.4 Application Notes 6.0 Packaging Information 6.1 Package Marking Information
