Datasheet ADA4857-1, ADA4857-2 (Analog Devices)
DescriptionUltralow Distortion, Low Power, Low Noise, High Speed Op Amp
Pages / Page21 / 1 — Ultralow Distortion, Low Power,. Low Noise, High Speed Op Amp. Data …
RevisionD
File Format / SizePDF / 556 Kb
Ultralow Distortion, Low Power,. Low Noise, High Speed Op Amp. Data Sheet. ADA4857-1. /ADA4857-2. FEATURES. CONNECTION DIAGRAMS
Datasheet ADA4857-1, ADA4857-2 Analog Devices, Revision: D
Ultralow Distortion, Low Power, Low Noise, High Speed Op Amp Data Sheet ADA4857-1 /ADA4857-2 FEATURES CONNECTION DIAGRAMS High speed ADA4857-1 TOP VIEW 850 MHz, −3 dB bandwidth (G = +1, RL = 1 kΩ, LFCSP) (Not to Scale) 750 MHz, −3 dB bandwidth (G = +1, RL = 1 kΩ, SOIC) PD 1 8 +VS 2800 V/μs slew rate FB 2 7 OUT Low distortion: −88 dBc at 10 MHz (G = +1, RL = 1 kΩ) –IN 3 6 NC Low power: 5 mA/amplifier at 10 V +IN 4 5 –VS Low noise: 4.4 nV/√Hz Wide supply voltage range: 5 V to 10 V NOTES 1. NC = NO CONNECT. DO NOT CONNECT Power-down feature TO THIS PIN. 2. THE EXPOSED PAD MAY BE CONNECTED
-001
Available in 3 mm × 3 mm 8-lead LFCSP (single), 8-lead SOIC TO GND OR VS.
07040
(single), and 4 mm × 4 mm 16-lead LFCSP (dual)
Figure 1. 8-Lead LFCSP (CP)
APPLICATIONS ADA4857-1 TOP VIEW (Not to Scale) Instrumentation FB 1 8 PD IF and baseband amplifiers –IN 2 7 +VS Active filters +IN 3 6 OUT ADC drivers –VS 4 5 NC
02
DAC buffers
0 0-
NC = NO CONNECT
04 07 Figure 2. 8-Lead SOIC (R)
ADA4857-2 TOP VIEW (Not to Scale) 1 1 T1 S1 FB PD +V OU 6 5 4 3 1 1 1 1 –IN1 1 12 –VS1 +IN1 2 11 NC NC 3 10 +IN2 –V 4 9 S2 –IN2 5 6 7 8 2 2 2 T S2 PD FB OU +V NOTES 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
003
40-
TO GND OR VS.
070 Figure 3. 16-Lead LFCSP (CP)
GENERAL DESCRIPTION
The ADA4857 is a unity-gain stable, high speed, voltage feedback 10 V), the ADA4857 is an ideal candidate for systems that require amplifier with low distortion, low noise, and high slew rate. With a high dynamic range, precision, and speed. spurious-free dynamic range (SFDR) of −88 dBc at 10 MHz, the The ADA4857-1 amplifier is available in a 3 mm × 3 mm, 8-lead ADA4857 is an ideal solution for a variety of applications, including LFCSP and a standard 8-lead SOIC. The ADA4857-2 is available in ultrasounds, ATE, active filters, and ADC drivers. The Analog a 4 mm × 4 mm, 16-lead LFCSP. The LFCSP features an exposed Devices, Inc., proprietary next-generation XFCB process and paddle that provides a low thermal resistance path to the printed innovative architecture enables such high performance amplifiers. circuit board (PCB). This path enables more efficient heat transfer The ADA4857 has 850 MHz bandwidth, 2800 V/μs slew rate, and and increases reliability. The ADA4857 works over the extended settles to 0.1% in 15 ns. With a wide supply voltage range (5 V to industrial temperature range (−40°C to +125°C).
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2008–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ±5 V SUPPLY +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS APPLICATIONS INFORMATION POWER-DOWN OPERATION CAPACITIVE LOAD CONSIDERATIONS RECOMMENDED VALUES FOR VARIOUS GAINS ACTIVE LOW-PASS FILTER (LPF) NOISE CIRCUIT CONSIDERATIONS PCB LAYOUT POWER SUPPLY BYPASSING GROUNDING OUTLINE DIMENSIONS ORDERING GUIDE
