Datasheet ADA4899-1 (Analog Devices) - 3
DescriptionUnity-Gain Stable, Ultralow Distortion, 1 nV/√Hz Voltage Noise, High Speed Op Amp
Pages / Page22 / 3 — DOCUMENT FEEDBACK
RevisionC
File Format / SizePDF / 668 Kb
DOCUMENT FEEDBACK
DOCUMENT FEEDBACK
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION PACKAGING INNOVATION DISABLE\ PIN APPLICATIONS INFORMATION UNITY-GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE ADC DRIVER DISABLE\ PIN OPERATION ADA4899-1 MUX CIRCUIT CONSIDERATIONS PCB Layout Power Supply Bypassing Grounding OUTLINE DIMENSIONS ORDERING GUIDE
