Datasheet AD8003 (Analog Devices) - 10
DescriptionTriple, 1.5 GHz Op Amp
Pages / Page17 / 10 — Data Sheet. AD8003. 6000. G = +2. RISE. INPUT. G = +1. RL = 150Ω. FALL. S …
RevisionC
File Format / SizePDF / 771 Kb
Data Sheet. AD8003. 6000. G = +2. RISE. INPUT. G = +1. RL = 150Ω. FALL. S = ±5V. 5000. OUTPUT. s) 4000. E (. A 3000. PL –1. S = +5V. SL 2000. 1000. 0.1. 0.2. 0.3
Data Sheet AD8003 6000 G = +2 RISE INPUT G = +1 RL = 150Ω FALL S = ±5V 5000 OUTPUT s) 4000 E ( A 3000 PL –1 S = +5V SL 2000 1000 0.1 0.2 0.3
Data Sheet AD8003 6000 5 G = +2 RISE INPUT G = +1 RL = 150Ω FALL V V S = ±5V 4 S = ±5V RL = 150Ω 5000 3 OUTPUT 2 s) 4000 µ V) V/ 1 E ( E ( D T U A 3000 0 IT R PL –1 EW V M S = +5V A SL 2000 –2 –3 1000
13 23
–4
0 0 1- 1- 72 72 05
0
05
–5 0 1 2 3 4 5 6 7 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 V TIME (µs) OUT p-p (V)
Figure 22. Slew Rate vs. Output Voltage Figure 25. Input Overdrive Recovery
5 1000 INPUT × 2 G = +2 G = +1/+2 VS = ±5V V 4 S = ±5V RL = 150Ω 3 OUTPUT 100 2 ) V) 1 (Ω E ( D CE U 0 10 IT DAN PL E –1 M P A IM –2 1 –3
24
–4
27 0 0 1- 1- 72 572 05
–5
0
0.1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 0.1 1 10 100 1000 TIME (µs) FREQUENCY (MHz)
Figure 23. Output Overdrive Recovery Figure 26. Output Impedance vs. Frequency
0 0 G = 0 G = +2 VS = ±5V VS = ±5V RL = 150Ω RL = 150Ω –10 –10 B) B) d d N ( N ( –20 IO IO –20 CT CT JE JE –30 E RE –30 R E Y PSR– D L O P –40 P -M U N –40 S O R M –50 E M W PSR+ O CO –50 P –60
26 25 0 0 1- 1- 572 572 0
–60
0
–70 0.1 1 10 100 0.1 1 10 100 1000 FREQUENCY (MHz) FREQUENCY (MHz)
Figure 24. Common-Mode Rejection vs. Frequency Figure 27. Power Supply Rejection vs. Frequency Rev. C | Page 9 of 16 Document Outline Features Applications Connection Diagram General Description Table of Contents Revision History Specifications with ±5 V Supply Specifications with +5 V Supply Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Typical Performance Characteristics Applications Information Gain Configurations RGB Video Driver Printed Circuit Board Layout Low Distortion Pinout Signal Routing Exposed Paddle Power Supply Bypassing Grounding Outline Dimensions Ordering Guide
