Datasheet AD8022 (Analog Devices) - 2
DescriptionDual High Speed, Low Noise Op Amp
Pages / Page18 / 2 — AD8022* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 330 Kb
AD8022* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE DESIGNS. EVALUATION KITS
AD8022* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE DESIGNS EVALUATION KITS
View a parametric search of comparable parts. • CN0039 • CN0048
EVALUATION KITS
• ADSP-SC584 Evaluation Hardware for the ADSP-SC58x/
REFERENCE MATERIALS
ADSP-2158x SHARC Family (349-ball CSPBGA)
Product Selection Guide
• ADSP-SC589 Evaluation Hardware for the ADSP-SC58x/ • High Speed Amplifiers Selection Table ADSP-2158x SHARC Family (529-ball CSPBGA) • SAR ADC & Driver Quick-Match Guide • Universal Evaluation Board for Dual High Speed Operational Amplifiers
Technical Articles
• Maximize Performance When Driving Differential ADCs
DOCUMENTATION Tutorials Application Notes
• MT-032: Ideal Voltage Feedback (VFB) Op Amp • AN-356: User's Guide to Applying and Measuring • MT-033: Voltage Feedback Op Amp Gain and Bandwidth Operational Amplifier Specifications • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS • AN-402: Replacing Output Clamping Op Amps with Input Noise, and Equivalent Noise Bandwidth Clamping Amps • MT-049: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Single-Pole System Design Constraints in Low Voltage High Speed Systems • MT-050: Op Amp Total Output Noise Calculations for • AN-581: Biasing and Decoupling Op Amps in Single Second-Order System Supply Applications • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-649: Using the Analog Devices Active Filter Design • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Tool SFDR, MTPR • AN-851: A WiMax Double Downconversion IF Sampling • MT-056: High Speed Voltage Feedback Op Amps Receiver Design • MT-058: Effects of Feedback Capacitance on VFB and CFB
Data Sheet
Op Amps • AD8022: Dual High Speed Low Noise Op Amp Data Sheet • MT-059: Compensating for the Effects of Input
User Guides
Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters • UG-128: Universal Evaluation Board for Dual High Speed Op Amps in SOIC Packages • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps • UG-886: Universal Evaluation Board for Dual High Speed Op Amps Offered in 8-Lead MSOP
DESIGN RESOURCES TOOLS AND SIMULATIONS
• AD8022 Material Declaration • Analog Filter Wizard • PCN-PDN Information • Analog Photodiode Wizard • Quality And Reliability • Power Dissipation vs Die Temp • Symbols and Footprints • VRMS/dBm/dBu/dBV calculators
DISCUSSIONS
• AD8022 SPICE Macro-Model View all AD8022 EngineerZone Discussions. Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTIONS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS DMT MODULATION AND MULTITONE POWER RATIO (MTPR) CHANNEL CAPACITY AND SNR POWER SUPPLY AND DECOUPLING LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
