Datasheet AD8057, AD8058 (Analog Devices) - 5
DescriptionLow Cost, Dual, High Performance Voltage Feedback, 325 MHz Amplifier
Pages / Page16 / 5 — Data Sheet. AD8057/AD8058. ABSOLUTE MAXIMUM RATINGS. MAXIMUM POWER …
RevisionE
File Format / SizePDF / 353 Kb
Data Sheet. AD8057/AD8058. ABSOLUTE MAXIMUM RATINGS. MAXIMUM POWER DISSIPATION. Table 3. Parameter. Rating. 2.0. TJ = 150°C. (W N 1.5
Data Sheet AD8057/AD8058 ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Table 3 Parameter Rating 2.0 TJ = 150°C (W N 1.5
link to page 5
Data Sheet AD8057/AD8058 ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Table 3. Parameter Rating
The maximum power that can be safely dissipated by the Supply Voltage (+V AD8057/AD8058 is limited by the associated rise in junction S to –VS) 12.6 V Internal Power Dissipation1 temperature. Exceeding a junction temperature of 175°C for SOIC Package (R) 0.8 W an extended period can result in device failure. Although the SOT-23-5 Package (RT) 0.5 W AD8057/AD8058 is internally short-circuit protected, this may MSOP Package (RM) 0.6 W not be sufficient to guarantee that the maximum junction temper- Input Voltage (Common Mode) ±V ature (150°C) is not exceeded under all conditions. To ensure S Differential Input Voltage ±4.0 V proper operation, it is necessary to observe the maximum power Output Short-Circuit Duration derating curves. Observe power derating curves
2.0
Storage Temperature Range (R) −65°C to +125°C
TJ = 150°C )
Operating Temperature Range (A Grade) −40°C to +85°C
(W N 1.5 IO T
Lead Temperature (Soldering 10sec) 300°C
PA 8-LEAD SOIC
1 Specification is for device in free air:
ISSI D 8-LEAD MSOP
8-lead SOIC package: θ
1.0
JA = 160°C/W
ER
5-lead SOT-23-5 package: θJA = 240°C/W
W
8-Lead MSOP package: θJA = 200°C/W
M PO
Stresses above those listed under Absolute Maximum Ratings
MU 0.5 SOT-23-5
may cause permanent damage to the device. This is a stress
XI MA
rating only; functional operation of the device at these or any other conditions above those indicated in the operational
0
005 section of this specification is not implied. Exposure to absolute
–50 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 AMBIENT TEMPERATURE (°C)
01064- maximum rating conditions for extended periods may affect Figure 5. Maximum Power Dissipation vs. Ambient Temperature device reliability.
ESD CAUTION
Rev. E | Page 5 of 16 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipations ESD Caution Typical Performance Characteristics Test Circuits Applications Information Driving Capacitive Loads Video Filter Differential Analog-to-Digital Driver Layout Outline Dimensions Ordering Guide
