Datasheet AD817 (Analog Devices) - 5
DescriptionHigh Speed, Low Power Wide Supply Range Amplifier
Pages / Page14 / 5 — AD817. AD817A. Parameter. Conditions. Min. Typ. Max. Units. ABSOLUTE …
RevisionB
File Format / SizePDF / 252 Kb
AD817. AD817A. Parameter. Conditions. Min. Typ. Max. Units. ABSOLUTE MAXIMUM RATINGS1. 2.0. 8-PIN MINI-DIP PACKAGE. TJ = +150. 1.5. 1.0
AD817 AD817A Parameter Conditions Min Typ Max Units ABSOLUTE MAXIMUM RATINGS1 2.0 8-PIN MINI-DIP PACKAGE TJ = +150 1.5 1.0
AD817 AD817A Parameter Conditions VS Min Typ Max Units
INPUT COMMON-MODE ±5 V +3.8 +4.3 V VOLTAGE RANGE –2.7 –3.4 V ±15 V +13 +14.3 V –12 –13.4 V 0, +5 V +3.8 +4.3 V +1.2 +0.9 V OUTPUT VOLTAGE SWING RLOAD = 500 Ω ±5 V 3.3 3.8 ±V RLOAD = 150 Ω ±5 V 3.2 3.6 ±V RLOAD = 1 kΩ ±15 V 13.3 13.7 ±V RLOAD = 500 Ω ±15 V 12.8 13.4 ±V RLOAD = 500 Ω 0, +5 V +1.5, +3.5 V Output Current ±15 V 50 mA ±5 V 50 mA 0, +5 V 30 mA Short-Circuit Current ±15 V 90 mA INPUT RESISTANCE 300 kΩ INPUT CAPACITANCE 1.5 pF OUTPUT RESISTANCE Open Loop 8 Ω POWER SUPPLY Operating Range Dual Supply ±2.5 ±18 V Single Supply +5 +36 V Quiescent Current ±5 V 7.0 7.5 mA T ± MIN to TMAX 5 V 7.5 mA ±15 V 7.5 mA T ± MIN to TMAX 15 V 7.0 7.5 mA NOTES 1Full power bandwidth = slew rate/2 π VPEAK. Specifications subject to change without notice.
Supply Voltage . ± 18 V
C
Internal Power Dissipation2 Plastic (N) . See Derating Curves
1.5
Small Outline (R) . See Derating Curves Input Voltage (Common Mode) . ± VS Differential Input Voltage . ± 6 V
1.0
Output Short Circuit Duration . See Derating Curves Storage Temperature Range N, R . –65°C to +125°C Operating Temperature Range . – 40°C to +85°C
8-PIN SOIC PACKAGE
Lead Temperature Range (Soldering 10 sec) . +300°C
0.5
NOTES
MAXIMUM POWER DISSIPATION – Watts
1Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional
0 –50 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90
operation of the device at these or any other conditions above those indicated in the
AMBIENT TEMPERATURE –
C
operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2Specification is for device in free air: 8-pin plastic package: θJA = 100°C/watt; Maximum Power Dissipation vs. Temperature 8-pin SOIC package: θJA = 160°C/watt.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection.
WARNING!
Although the AD817 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD
ESD SENSITIVE DEVICE
precautions are recommended to avoid performance degradation or loss of functionality. REV. B –3–
