Datasheet OP200 (Analog Devices) - 10
DescriptionDual Low Offset, Low Power Operational Amplifier
Pages / Page17 / 10 — Data Sheet. OP200. 100. 1.18. TA = 25°C. TWO AMPLIFIERS. VS = ±15V. A = …
RevisionG
File Format / SizePDF / 414 Kb
Data Sheet. OP200. 100. 1.18. TA = 25°C. TWO AMPLIFIERS. VS = ±15V. A = 25°C. 1.16. /√Hz. V n. ( Y. 1.14. NS DE. CURR. 1.12. Y L. 1.10. 1.08. 1.06. ±10. ±14. ±18
Data Sheet OP200 100 1.18 TA = 25°C TWO AMPLIFIERS VS = ±15V A = 25°C 1.16 /√Hz V n ( Y 1.14 NS DE CURR 1.12 Y L 1.10 1.08 1.06 ±10 ±14 ±18
Data Sheet OP200 100 1.18 TA = 25°C TWO AMPLIFIERS VS = ±15V T ) A = 25°C 1.16 /√Hz A) V n (m ( Y NT 1.14 IT E NS DE CURR E 1.12 Y L IS P O P N U E S 1.10 AG AL T T L O O T V 1.08
12 15 0 0 2- 2- 32 32
10
00
1.06
00
1 10 100 1k ±2 ±6 ±10 ±14 ±18 FREQUENCY (Hz) SUPPLY VOLTAGE (V)
Figure 12. Voltage Noise Density vs. Frequency Figure 15. Total Supply Current vs. Supply Voltage
1000 1.16 TA = 25°C TWO AMPLIFIERS VS = ±15V V ) S = ±15V ) √Hz A 1.15 m ( (fA/ Y NT IT E S 1.14 N DE CURR E Y IS L P P 1.13 NO U NT S E AL T O 1.12 T CURR
13 16 0 0 2- 2- 32 32
100
00
1.11
00
1 10 100 1k –75 –50 –25 0 25 50 75 100 125 FREQUENCY (Hz) TEMPERATURE (°C)
Figure 13. Current Noise Density vs. Frequency Figure 16. Total Supply Current vs. Temperature
140 120 NEGATIVE SUPPLY ) ) A V n ( /DI N 100 V IO T 400n EC ( 80 E EJ R AG Y T L L 60 O PP V POSITIVE SUPPLY E SU IS R 40 E NO W PO 20
4 17 01 0
T
2-
A = 25°C
2- 32 32 00
0
00
0 2 4 6 8 10 0.1 1 10 100 1k 10k 100k TIME (SEC) FREQUENCY (Hz)
Figure 14. 0.1 Hz to 10 Hz Noise Figure 17. Power Supply Rejection vs. Frequency Rev. G | Page 9 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
