Datasheet OP42 (Analog Devices) - 2
DescriptionHigh Speed, Fast Settling Precision Operational Amplifier
Pages / Page15 / 2 — OP42* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 644 Kb
OP42* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
OP42* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
EVALUATION KITS
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth • EVAL-OPAMP-1 Evaluation Board • MT-047: Op Amp Noise • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
DOCUMENTATION
Noise, and Equivalent Noise Bandwidth
Application Notes
• MT-049: Op Amp Total Output Noise Calculations for • AN-108: JFET-Input Amps are Unrivaled for Speed and Single-Pole System Accuracy • MT-050: Op Amp Total Output Noise Calculations for • AN-117: OP-42 Advanced SPICE Macro-Model Second-Order System • AN-138: SPICE-Compatible Op Amp Macro-Models • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-402: Replacing Output Clamping Op Amps with Input • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Clamping Amps SFDR, MTPR • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-056: High Speed Voltage Feedback Op Amps Design Constraints in Low Voltage High Speed Systems • MT-058: Effects of Feedback Capacitance on VFB and CFB • AN-581: Biasing and Decoupling Op Amps in Single Op Amps Supply Applications • MT-059: Compensating for the Effects of Input
Data Sheet
Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters • OP42: High Speed, Fast Settling Precision Operational Amplifier Data Sheet • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps • OP42: Military Data Sheet
User Guides DESIGN RESOURCES
• UG-755: 8-Lead SOIC Amplifier Evaluation Board User • OP42 Material Declaration Guide • PCN-PDN Information
TOOLS AND SIMULATIONS
• Quality And Reliability • Analog Filter Wizard • Symbols and Footprints • Analog Photodiode Wizard
DISCUSSIONS
• Power Dissipation vs Die Temp View all OP42 EngineerZone Discussions. • VRMS/dBm/dBu/dBV calculators • OP42 SPICE Macro-Model
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
