Datasheet LTC1409 (Analog Devices) - 10
Description12-Bit, 800ksps Sampling A/D Converter with Shutdown
Pages / Page20 / 10 — APPLICATIONS INFORMATION. Figure 5. Intermodulation Distortion Plot. Full …
File Format / SizePDF / 356 Kb
APPLICATIONS INFORMATION. Figure 5. Intermodulation Distortion Plot. Full Power and Full Linear Bandwidth
APPLICATIONS INFORMATION Figure 5 Intermodulation Distortion Plot Full Power and Full Linear Bandwidth
LTC1409
U U W U APPLICATIONS INFORMATION
0 fSAMPLE = 800kHz fIN1 = 88.19580078kHz –20 fIN2 = 111.9995117kHz –40 –60 fb – fa fa + fb 2fa + fb fa + 2fb 3fa AMPLITUDE (dB) –80 2fa – fb 2fb – fa 2fb 2fa 3fb –100 –120 0 50k 100k 150k 200k 250k 300k 350k 400k FREQUENCY (Hz) LTC1409 • F05
value is expressed in decibels relative to the RMS value of minimum acquisition time, with high source impedance, a full-scale input signal. a buffer amplifier should be used. The only requirement is that the amplifier driving the analog input(s) must
settle after the small current spike before the next conver- The full power bandwidth is that input frequency at which sion starts (settling time must be 150ns for full through- the amplitude of the reconstructed fundamental is put rate). reduced by 3dB for a full-scale input signal. 10 The full linear bandwidth is the input frequency at which the S/(N + D) has dropped to 68dB (11 effective bits). The µs) 1 LTC1409 has been designed to optimize input bandwidth, allowing the ADC to undersample input signals with fre- quencies above the converter’s Nyquist Frequency. The noise floor stays very low at high frequencies; S/(N + D) 0.1 ACQUISITION TIME ( becomes dominated by distortion at frequencies far beyond Nyquist. 0.010.01 0.1 1 10 100
Driving the Analog Input
SOURCE RESISTANCE (kΩ) LTC1409 • F06 The differential analog inputs of the LTC1409 are easy to drive. The inputs may be driven differentially or as a
Figure 6. Acquisition Time vs Source Resistance
single-ended input (i.e., the –AIN input is grounded). The
Choosing an Input Amplifier
+AIN and –AIN inputs are sampled at the same instant. Any unwanted signal that is common mode to both Choosing an input amplifier is easy if a few requirements inputs will be reduced by the common mode rejection of are taken into consideration. First, to limit the magnitude the sample-and-hold circuit. The inputs draw only one of the voltage spike seen by the amplifier from charging small current spike while charging the sample-and-hold the sampling capacitor, choose an amplifier that has a capacitors at the end of conversion. During conversion low output impedance (< 100Ω) at the closed-loop band- the analog inputs draw only a small leakage current. If the width frequency. For example, if an amplifier is used in a source impedance of the driving circuit is low then the gain of 1 and has a unity-gain bandwidth of 50MHz, then LTC1409 inputs can be driven directly. As source imped- the output impedance at 50MHz should be less than ance increases so will acquisition time (see Figure 6). For 100Ω. The second requirement is that the closed-loop 10
