Datasheet LTC2142-12, LTC2141-12, LTC2140-12 (Analog Devices) - 5
Description12-Bit, 65Msps Low Power Dual ADCs
Pages / Page38 / 5 — DYNAMIC ACCURACY. The. denotes the specifications which apply over the …
DYNAMIC ACCURACY. The. denotes the specifications which apply over the full operating temperature range,
DYNAMIC ACCURACY The denotes the specifications which apply over the full operating temperature range,
LTC2142-12/ LTC2141-12/LTC2140-12
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. AIN = –1dBFS. (Note 5) LTC2142-12 LTC2141-12 LTC2140-12 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 5MHz Input 70.8 70.5 71 dBFS 30MHz Input l 69.6 70.8 69.2 70.5 69.7 71 dBFS 70MHz Input 70.7 70.4 70.9 dBFS 140MHz Input 70.5 70.2 70.7 dBFS SFDR Spurious Free Dynamic Range 5MHz Input 89 89 89 dBFS 2nd Harmonic 30MHz Input l 78 89 80 89 80 89 dBFS 70MHz Input 88 88 88 dBFS 140MHz Input 84 84 84 dBFS Spurious Free Dynamic Range 5MHz Input 89 89 89 dBFS 3rd Harmonic 30MHz Input l 80 89 80 89 80 89 dBFS 70MHz Input 88 88 88 dBFS 140MHz Input 84 84 84 dBFS Spurious Free Dynamic Range 5MHz Input 95 95 95 dBFS 4th Harmonic or Higher 30MHz Input l 85 95 85 95 85 95 dBFS 70MHz Input 95 95 95 dBFS 140MHz Input 95 95 95 dBFS S/(N+D) Signal-to-Noise Plus 5MHz Input 70.7 70.4 70.9 dBFS Distortion Ratio 30MHz Input l 69.4 70.7 69.1 70.4 69.6 70.9 dBFS 70MHz Input 70.6 70.3 70.8 dBFS 140MHz Input 70.2 69.9 70.4 dBFS Crosstalk 10MHz Input –110 –110 –110 dBc
INTERNAL REFERENCE CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
VCM Output Voltage IOUT = 0 0.5 • VDD – 25mV 0.5 • VDD 0.5 • VDD + 25mV V VCM Output Temperature Drift ±25 ppm/°C VCM Output Resistance –600μA < IOUT < 1mA 4 Ω VREF Output Voltage IOUT = 0 1.225 1.250 1.275 V VREF Output Temperature Drift ±25 ppm/°C VREF Output Resistance –400μA < IOUT < 1mA 7 Ω VREF Line Regulation 1.7V < VDD < 1.9V 0.6 mV/V 21421012fa 5
