Datasheet LTC2439-1 (Analog Devices) - 3
Description8-/16-Channel 16-Bit No Latency ∆Σ™ ADC
Pages / Page30 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 583 Kb
LTC2439-1
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Notes 3, 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Negative Full-Scale Error 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 0.16 1.25 LSB IN+ = 0.25 • REF+, IN– = 0.75 • REF+ (Note 15) Negative Full-Scale Error Drift 2.5V ≤ REF+ ≤ VCC, REF– = GND, 0.03 ppm of VREF/°C IN+ = 0.25 • REF+, IN– = 0.75 • REF+
CONVERTER CHARACTERISTICS The
Total Unadjusted Error 5V ≤ VCC ≤ 5.5V, REF+ = 2.5V, REF– = GND, VINCM = 1.25V 0.20 LSB 5V ≤ VCC ≤ 5.5V, REF+ = 5V, REF– = GND, VINCM = 2.5V 0.20 LSB REF+ = 2.5V, REF– = GND, VINCM = 1.25V, (Note 6) Output Noise 5V ≤ V – CC ≤ 5.5V, REF+ = 5V, VREF = GND, 1 µVRMS GND ≤ IN– = IN+ ≤ 5V (Note 12) Input Common Mode Rejection DC 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 130 140 dB GND ≤ IN– = IN+ ≤ VCC (Note 5) Input Common Mode Rejection 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 140 dB 49Hz to 61.2Hz GND ≤ IN– = IN+ ≤ VCC, (Note 5) Input Normal Mode Rejection (Note 5) l 87 dB 49Hz to 61.2Hz Reference Common Mode 2.5V ≤ REF+ ≤ VCC, GND ≤ REF– ≤ 2.5V, l 130 140 dB Rejection DC VREF = 2.5V, IN– = IN+ = GND (Note 5) Power Supply Rejection, DC REF+ = 2.5V, REF– = GND, IN– = IN+ = GND 120 dB Power Supply Rejection, REF+ = 2.5V, REF– = GND, IN– = IN+ = GND 120 dB Simultaneous 50Hz/60Hz ±2%
ANALOG INPUT AND REFERENCE The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IN+ Absolute/Common Mode IN+ Voltage l GND – 0.3 VCC + 0.3 V IN– Absolute/Common Mode IN– Voltage l GND – 0.3 VCC + 0.3 V VIN Input Differential Voltage Range (IN+ – IN–) l –VREF/2 VREF/2 V REF+ Absolute/Common Mode REF+ Voltage l 0.1 VCC V REF– Absolute/Common Mode REF– Voltage l GND VCC – 0.1 V VREF Reference Differential Voltage Range l 0.1 VCC V (REF+ – REF–) CS (IN+) IN+ Sampling Capacitance 18 pF CS (IN–) IN– Sampling Capacitance 18 pF CS (REF+) REF+ Sampling Capacitance 18 pF CS (REF–) REF– Sampling Capacitance 18 pF IDC_LEAK (IN+) IN+ DC Leakage Current CS = VCC = 5.5V, IN+ = GND l –100 1 100 nA IDC_LEAK (IN–) IN– DC Leakage Current CS = VCC = 5.5V, IN– = 5V l –100 1 100 nA IDC_LEAK (REF+) REF+ DC Leakage Current CS = VCC = 5.5V, REF+ = 5V l –100 1 100 nA IDC_LEAK (REF–) REF– DC Leakage Current CS = VCC = 5.5V, REF– = GND l –100 1 100 nA 24391fb For more information www.linear.com/LTC2439-1 3 Document Outline Features Applications Typical Application Absolute Maximum Ratings Order Information Electrical Characteristics Converter Characteristics Analog Input and Reference Digital Inputs and Digital Outputs POWER REQUIREMENTS Timing Characteristics Pin Functions FUNCTIONAL Block Diagram Test CircuitS Applications Information Package Description Revision History Typical Application Related Parts
