Datasheet LTM9008-14, LTM9007-14, LTM9006-14 (Analog Devices) - 2
Description14-Bit, 65Msps Low Power Octal ADCs
Pages / Page38 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2)
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 2)
LTM9008-14/ LTM9007-14/LTM9006-14
Supply Voltages TOP VIEW VDD, OVDD .. –0.3V to 2V Analog Input Voltage (A + – IN , AIN , A PAR/SER, SENSE) (Note 3) .. –0.3V to (VDD + 0.2V) B Digital Input Voltage (ENC+, ENC–, CS, C SDI, SCK) (Note 4) .. –0.3V to 3.9V D SDO (Note 4) ... –0.3V to 3.9V E Digital Output Voltage .. –0.3V to (OVDD + 0.3V) F Operating Temperature Range G LTM9008C, LTM9007C, LTM9006C... 0°C to 70°C H LTM9008I, LTM9007I, LTM9006I ..–40°C to 85°C J Storage Temperature Range .. –55°C to 125°C K L M N P 1 2 3 4 5 6 7 8 9 10 BGA PACKAGE 140-LEAD (11.25mm × 9.00mm × 2.72mm) TJMAX = 150°C, θJA = 30°C/W, θJC = 25°C/W, θJB = 15°C/W, θJCbottom = 12°C/W
ORDER INFORMATION http://www.linear.com/product/LTM9008-14#orderinfo LEAD FREE FINISH TRAY PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTM9008CY-14#PBF LTM9008CY-14#PBF LTM9008Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA 0°C to 70°C LTM9008IY-14#PBF LTM9008IY-14#PBF LTM9008Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA –40°C to 85°C LTM9007CY-14#PBF LTM9007CY-14#PBF LTM9007Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA 0°C to 70°C LTM9007IY-14#PBF LTM9007IY-14#PBF LTM9007Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA –40°C to 85°C LTM9006CY-14#PBF LTM9006CY-14#PBF LTM9006Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA 0°C to 70°C LTM9006IY-14#PBF LTM9006IY-14#PBF LTM9006Y14 140-Lead (11.25mm × 9mm × 2.72mm) BGA –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 90067814fb 2 For more information www.linear.com/LTM9008-14 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Outputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Pin Configuration Table Functional Block Diagram Applications Information Package Description Related Parts
