Datasheet LT3050 (Analog Devices) - 6
Description100mA, Linear Regulator with Precision Current Limit and Diagnostic Outputs
Pages / Page26 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. …
File Format / SizePDF / 409 Kb
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. Typical Dropout Voltage. Guaranteed Dropout Voltage
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted Typical Dropout Voltage Guaranteed Dropout Voltage
LT3050 Series
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. Typical Dropout Voltage Guaranteed Dropout Voltage Dropout Voltage
600 600 600 =TEST POINTS 550 550 550 I 500 500 500 L = 100mA 450 450 450 T T I J ≤ 125°C J = 125°C L = 50mA 400 400 400 TAGE (mV) 350 TAGE (mV) 350 TAGE (mV) 350 300 300 TJ = 25°C 300 IL = 10mA 250 250 250 TJ ≤ 25°C 200 200 200 IL = 1mA DROPOUT VOL 150 DROPOUT VOL 150 DROPOUT VOL 150 100 100 100 50 50 50 0 0 0 0 10 20 30 40 50 60 70 80 90 100 0 10 20 30 40 50 60 70 80 90 100 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) TEMPERATURE (°C) 3050 G01 3050 G02 3050 G03
Adjustable Quiescent Current ADJ Pin Voltage Output Voltage LT3050-3.3
80 612 3.366 I I 610 LOAD = 1mA 3.355 LOAD = 1mA 70 608 3.344 60 V 606 3.333 IN = VSHDN = 12V VOUT = 5V 604 3.322 50 IL = 5μA 602 3.311 TAGE (mV) TAGE (V) 40 600 3.300 598 3.289 30 596 3.278 ADJ PIN VOL OUTPUT VOL QUIESCENT CURRENT (μA) 20 594 3.267 592 3.256 10 VIN = 12V ALL OTHER PINS = 0V 590 3.245 0 588 3.234 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3050 G04 3050 G05 3050 G05a
Output Voltage LT3050-5 Quiescent Current GND Pin Current LT3050-3.3
5.100 100 2.50 ILOAD = 1mA TJ = 25°C 90 5.075 I 2.25 LOAD = 10μA 80 LT3050-5 2.00 RL = 33Ω, IL = 100mA 5.050 70 1.75 5.025 60 1.50 TAGE (V) 5.000 50 1.25 RL = 66Ω, IL = 50mA 40 LT3050-3.3 1.00 4.975 OUTPUT VOL 30 0.75 GND PIN CURRENT (mA) 4.950 QUIESCENT CURRENT (μA) RL = 3.3k, IL = 1mA 20 0.50 R 4.925 L = 330Ω, IL = 10mA 10 0.25 VSHDN = 0V, RL = 0 4.900 0 0 –75 –50 –25 0 25 50 75 100 125 150 175 0 5 10 15 20 25 30 35 40 45 0 1 2 3 4 5 6 7 8 9 10 11 12 TEMPERATURE (°C) VIN (V) INPUT VOLTAGE (V) 3050 G06 3050 G07a 3050 G05b 3050fa 6 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM OPERATION APPLICATIONS INFORMATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
