Datasheet LT3060 (Analog Devices)
Description45V VIN, Micropower, Low Noise, 100mA Low Dropout, Linear Regulator
Pages / Page26 / 1 — FeaTures. DescripTion. Input Voltage Range: 1.6V to 45V. Output Current: …
File Format / SizePDF / 446 Kb
FeaTures. DescripTion. Input Voltage Range: 1.6V to 45V. Output Current: 100mA. Quiescent Current: 40µA. Dropout Voltage: 300mV
Datasheet LT3060 Analog Devices
LT3060
LT3060 Series 45V VIN, Micropower, Low Noise, 100mA Low Dropout, Linear Regulator
FeaTures DescripTion
n
The LT®3060 series are micropower, low dropout voltage n
(LDO) linear regulators that operate over a 1.6V to 45V n
input supply range. The devices supply 100mA of output n
current with a typical dropout voltage of 300mV. A single n
Low Noise: 30µVRMS (10Hz to 100kHz)
external capacitor provides programmable low noise n
Adjustable Output: VREF = 600mV
reference performance and output soft-start functional- n Fixed Output Voltages: 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, ity. The LT3060’s quiescent current is merely 40μA and 5V, 15V provides fast transient response with a minimum 2.2μF n Output Tolerance: ±2% Over Line, Load and output capacitor. In shutdown, quiescent current is less Temperature than 1μA and the reference soft-start capacitor is reset. n Single Capacitor Soft-Starts Reference and Lowers The LT3060 regulators optimize stability and transient Output Noise response with low ESR, ceramic output capacitors. n Shutdown Current: < 1µA The regulators do not require the addition of ESR as is n Reverse Battery Protection common with other regulators. n Current Limit Foldback Protection n Thermal Limit Protection Internal protection circuitry includes reverse-battery n 8-Lead 2mm × 2mm × 0.75mm DFN and 8-Lead protection, reverse-output protection, reverse-current ThinSOT™ Packages protection, current limit with foldback and thermal shutdown. The LT3060 series are available in fixed output voltages of 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 5V and 15V, and as
applicaTions
an adjustable voltage regulator with an output voltage range n Battery-Powered Systems from the 600mV reference to 44.5V. The LT3060 regulators n Automotive Power Supplies are offered in the thermally enhanced 8-lead TSOT-23 and n Industrial Power Supplies 8-lead (2mm × 2mm × 0.75mm) DFN packages. n Avionic Power Supplies L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks and ThinSOT is a trademark of Linear Technology Corporation. All other trademarks are the property n Portable Instruments of their respective owners.
Typical applicaTion Dropout Voltage
350
2.5V Low Noise Regulator
TJ = 25°C 300 VOUT IN OUT 2.5V AT 100mA 250 VIN 30µVRMS NOISE 3V TO 1µF LT3060-2.5 CFF 10µF 45V 10nF TAGE (mV) 200 SHDN ADJ 150 GND REF/BYP 100 DROPOUT VOL 10nF 50 3060 TA01 0 0 10 20 30 40 50 60 70 80 90 100 OUTPUT CURRENT (mA) 3060 TA02 3060fc For more information www.linear.com/LT3060 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Application Revision History Typical Application Related Parts
