Datasheet LT3062 (Analog Devices) - 4
Description45V VIN, Micropower, Low Noise, 200mA LDO
Pages / Page22 / 4 — elecTrical characTerisTics The. denotes the specifications which apply …
elecTrical characTerisTics The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LT3062 Series
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) PARAMETER CONDITIONS MIN TYP MAX UNITS
ADJ Pin Bias Current (Notes 4, 9) l 15 60 nA Shutdown Threshold VOUT = Off to On l 0.8 1.5 V VOUT = On to Off l 0.3 0.7 V SHDN Pin Current (Note 10) VSHDN = 0V l <1 µA VSHDN = 45V l 1.2 3 µA Quiescent Current in Shutdown VIN = 45V, VSHDN = 0V 0.3 1 µA Ripple Rejection LT3062-3.3 58 73 dB VIN – VOUT = 1.5V (AVG), VRIPPLE = 0.5VP-P, LT3062-5 55 70 dB fRIPPLE = 120Hz, ILOAD = 200mA LT3062 (Note 4) 70 85 dB Current Limit VIN = 7V, VOUT = 0 320 mA VIN = VOUT(NOMINAL) + 1V (Note 11), ΔVOUT = –5% l 220 mA Input Reverse Leakage Current VIN = -45V, VOUT = 0 l 1 mA Reverse Output Current (Note 13) LT3062-3.3: VOUT = 3.3V, VIN = VSHDN = 0V 5.2 15 µA LT3062-5: VOUT = 5V, VIN = VSHDN = 0V 5.2 15 µA LT3062: VOUT = 1.2V, VIN = VSHDN = 0V 0.2 10 µA
Note 1:
Note 6:
To satisfy minimum input voltage requirements, the LT3062 may cause permanent damage to the device. Exposure to any Absolute adjustable version is tested and specified for these conditions with an Maximum Rating condition for extended periods may affect device external resistor divider (bottom 60k, top 230k) for an output voltage of reliability and lifetime. 2.9V. The external resistor divider adds 10µA of DC load on the output.
Note 2:
Absolute maximum input to output differential voltage is not The external current is not factored into GND pin current. achievable with all combinations of rated IN pin and OUT pin voltages.
Note 7:
Dropout voltage is the minimum input-to-output voltage With the IN pin at 50V, the OUT pin may not be pulled below 0V. The total differential needed to maintain regulation at a specified output current. In measured voltage from IN to OUT must not exceed ±50V. If OUT is above dropout, the output voltage equals: (VIN – VDROPOUT). ground, do not pull IN more than 40V below OUT.
Note 8:
GND pin current is tested with VIN = VOUT(NOMINAL) + 0.6V and a
Note 3:
The LT3062 is tested and specified under pulse load conditions current source load. GND pin current will increase in dropout. See GND such that TJ ≅ TA. The LT3062E regulators are 100% tested at TA = 25°C pin current curves in the Typical Performance Characteristics section. For and performance is guaranteed from 0°C to 125°C. Performance at fixed voltage options, an internal resistor divider will add 5μA to the GND –40°C to 125°C is assured by design, characterization and correlation pin current. See the GND Pin Current curves in the Typical Performance with statistical process controls. The LT3062I regulators are guaranteed Characteristics section. over the full –40°C to 125°C operating junction temperature range. The
Note 9:
ADJ pin bias current flows out of the ADJ pin. LT3062MP regulators are 100% tested over the –55°C to 150°C operating
Note 10:
SHDN pin current flows into the SHDN pin. junction temperature. The LT3062H regulators are 100% tested at the 150°C operating junction temperature. High junction temperatures degrade
Note 11:
To satisfy requirements for minimum input voltage, current limit operating lifetimes. Operating lifetime is derated at junction temperature is tested at VIN = VOUT(NOMINAL) + 1V or VIN = 2.1V, whichever is greater. greater than 125°C.
Note 12:
This IC includes thermal limit which protects the device during
Note 4:
The LT3062 adjustable version is tested and specified for these momentary overload conditions. Junction temperature exceeds 125°C conditions with the ADJ connected to the OUT pin. (E-Grade and I-Grade) or 150°C (MP-Grade and H-Grade) when thermal limit is active. Continuous operation above the specified maximum
Note 5:
Maximum junction temperature limits operating conditions. The junction temperature may impair device reliability. regulated output voltage specification does not apply for all possible combinations of input voltage and output current. Limit the output current
Note 13:
Reverse output current is tested with the IN pin grounded and the range if operating at the maximum input voltage. Limit the input-to-output OUT pin forced to the specified voltage. This current flows into the OUT voltage differential if operating at maximum output current. Current limit pin and out of the GND pin. foldback limits the maximum output current as a function of input-to- output voltage. See Current Limit vs VIN – VOUT in the Typical Performance Characteristics section. 3062fa 4 For more information www.linear.com/LT3062
