Datasheet AD7607 (Analog Devices) - 10
Description8-Channel DAS with 14-Bit, Bipolar, Simultaneous Sampling ADC
Pages / Page33 / 10 — Data Sheet. AD7607. t12. CS AND RD. t17. DATA:. DB[15:0]. FRSTDATA. SCLK. …
RevisionD
File Format / SizePDF / 884 Kb
Data Sheet. AD7607. t12. CS AND RD. t17. DATA:. DB[15:0]. FRSTDATA. SCLK. t21. t20. t22. DOUTA,. DB13. DB12. DB11. DB1. DB0. OUTB. t29. t28. t10. t11. t16. t13
Data Sheet AD7607 t12 CS AND RD t17 DATA: DB[15:0] FRSTDATA SCLK t21 t20 t22 DOUTA, DB13 DB12 DB11 DB1 DB0 OUTB t29 t28 t10 t11 t16 t13
Data Sheet AD7607 t12 CS AND RD t t 13 16 t17 DATA: V1 V2 V3 V4 V5 V6 V7 V8 DB[15:0]
5 00 6-
FRSTDATA
09 08 Figure 5. Linked Parallel Mode, CS and RD
CS SCLK t21 t20 t t 19 t22 t 18 23 DOUTA, D DB13 DB12 DB11 DB1 DB0 OUTB t29 t t28 25 FRSTDATA
06 0 6- 809 0 Figure 6. Serial Read Operation (Channel 1)
CS t8 t9 t10 t11 RD t16 t13 t t t 14 17 15 DATA: DB[7:0] HIGH LOW HIGH LOW INVALID BYTE V1 BYTE V1 BYTE V8 BYTE V8 t26 t27 t29
7
t24
00 6-
FRSTDATA
09 08 Figure 7. BYTE Mode Read Operation Rev. C | Page 9 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CONVERTER DETAILS ANALOG INPUT Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter Track-and-Hold Amplifiers ADC TRANSFER FUNCTION INTERNAL/EXTERNAL REFERENCE External Reference Mode Internal Reference Mode TYPICAL CONNECTION DIAGRAM POWER-DOWN MODES CONVERSION CONTROL Simultaneous Sampling on All Analog Input Channels Simultaneously Sampling Two Sets of Channels DIGITAL INTERFACE PARALLEL INTERFACE (/SER/BYTE SEL = 0) PARALLEL BYTE INTERFACE (/SER/BYTE SEL = 1, DB15 = 1) SERIAL INTERFACE (/SER/BYTE SEL = 1) READING DURING CONVERSION DIGITAL FILTER LAYOUT GUIDELINES OUTLINE DIMENSIONS ORDERING GUIDE NOTES
