Datasheet AD7190 (Analog Devices) - 2
Description4.8 kHz Ultralow Noise 24-Bit Sigma-Delta ADC with PGA
Pages / Page41 / 2 — AD7190* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 689 Kb
AD7190* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE DESIGNS. EVALUATION KITS
AD7190* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE DESIGNS EVALUATION KITS
View a parametric search of comparable parts. • CN0102
EVALUATION KITS REFERENCE MATERIALS
• AD7190 Evaluation Board
Solutions Bulletins & Brochures
• Test & Instrumentation Solutions Bulletin, Volume 10,
DOCUMENTATION
Issue 3
Application Notes Tutorials
• AN-0979: Digital Filtering Options: AD7190, AD7192 • Tutorial on Technical and Performance Benefits of AD719x Family • AN-1069: Zero Latency for the AD7190, AD7192, AD7193, AD7194, and AD7195 • AN-1084: Channel Switching: AD7190, AD7192, AD7193,
DESIGN RESOURCES
AD7194, AD7195 • AD7190 Material Declaration • AN-1131: Chopping on the AD7190, AD7192, AD7193, • PCN-PDN Information AD7194, and AD7195 • Quality And Reliability
Data Sheet
• Symbols and Footprints • AD7190: 4.8 kHz Ultralow Noise 24-Bit Sigma-Delta ADC with PGA Data Sheet
DISCUSSIONS User Guides
View all AD7190 EngineerZone Discussions. • UG-222: Evaluation Board for the AD7190/AD7192 4.8 kHz Ultralow Noise 24-Bit Sigma-Delta ADCs
SAMPLE AND BUY SOFTWARE AND SYSTEMS REQUIREMENTS
Visit the product page to see pricing options. • AD7190 - Microcontroller No-OS Driver
TECHNICAL SUPPORT
• AD7192 IIO High Precision ADC Linux Driver Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS
• AD7190/AD7192 Digital Filter Models
DOCUMENT FEEDBACK
• Download the Active Functional Model to evaluate and Submit feedback for this data sheet. debug AD719x
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Characteristics Circuit and Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics RMS Noise and Resolution Sinc4 Chop Disabled Sinc3 Chop Disabled Sinc4 Chop Enabled Sinc3 Chop Enabled On-Chip Registers Communications Register Status Register Mode Register Configuration Register Data Register ID Register GPOCON Register Offset Register Full-Scale Register ADC Circuit Information Overview Filter, Output Data Rate, Settling Time Chop Disabled Chop Enabled 50 Hz/60 Hz Rejection Zero Latency Channel Sequencer Digital Interface Single Conversion Mode Continuous Conversion Mode Continuous Read Circuit Description Analog Input Channel PGA Bipolar/Unipolar Configuration Data Output Coding Clock Burnout Currents Reference Reference Detect Reset System Synchronization Temperature Sensor Bridge Power-Down Switch Logic Outputs Enable Parity Calibration Grounding and Layout Applications Information Weigh Scales Outline Dimensions Ordering Guide Automotive Products
