Datasheet AD9252 (Analog Devices) - 2
DescriptionOctal, 14-Bit, 50 MSPS, Serial LVDS, 1.8 V ADC
Pages / Page53 / 2 — AD9252* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
AD9252* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9252* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9252 IBIS Models
EVALUATION KITS
• AD9252 Evaluation Board
REFERENCE MATERIALS Customer Case Studies DOCUMENTATION
• National Instruments Case Study
Application Notes Technical Articles
• AN-282: Fundamentals of Sampled Data Systems • MS-2210: Designing Power Supplies for High Speed ADC • AN-345: Grounding for Low-and-High-Frequency Circuits • AN-501: Aperture Uncertainty and ADC System
DESIGN RESOURCES
Performance • AD9252 Material Declaration • AN-715: A First Approach to IBIS Models: What They Are • PCN-PDN Information and How They Are Generated • Quality And Reliability • AN-737: How ADIsimADC Models an ADC • Symbols and Footprints • AN-741: Little Known Characteristics of Phase Noise • AN-742: Frequency Domain Response of Switched-
DISCUSSIONS
Capacitor ADCs View all AD9252 EngineerZone Discussions. • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
SAMPLE AND BUY
• AN-812: MicroController-Based Serial Port Interface (SPI) Boot Circuit Visit the product page to see pricing options. • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs
TECHNICAL SUPPORT
• AN-835: Understanding High Speed ADC Testing and Submit a technical question or find your regional support Evaluation number. • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual
DOCUMENT FEEDBACK
• AN-935: Designing an ADC Transformer-Coupled Front Submit feedback for this data sheet. End
Data Sheet
• AD9252: Octal, 14-Bit, 50 MSPS, Serial LVDS, 1.8 V ADC Data Sheet
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations Differential Input Configurations Single-Ended Input Configuration Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Applications Information Design Guidelines Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Evaluation Board Power Supplies Input Signals Output Signals Default Operation and Jumper Selection Settings Alternative Analog Input Drive Configuration Outline Dimensions Ordering Guide
