Datasheet AD9287 (Analog Devices) - 2
DescriptionQuad, 8-Bit, 100 MSPS Serial LVDS 1.8 V A/D Converter
Pages / Page52 / 2 — AD9287* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionF
AD9287* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. DOCUMENTATION
AD9287* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS DOCUMENTATION
View a parametric search of comparable parts. • Visual Analog • AD9287 IBIS Models
DOCUMENTATION Application Notes REFERENCE MATERIALS
• AN-1142: Techniques for High Speed ADC PCB Layout
Technical Articles
• AN-282: Fundamentals of Sampled Data Systems • Matching An ADC To A Transformer • AN-345: Grounding for Low-and-High-Frequency Circuits • MS-2210: Designing Power Supplies for High Speed ADC • AN-501: Aperture Uncertainty and ADC System Performance
DESIGN RESOURCES
• AN-715: A First Approach to IBIS Models: What They Are • AD9287 Material Declaration and How They Are Generated • PCN-PDN Information • AN-737: How ADIsimADC Models an ADC • Quality And Reliability • AN-741: Little Known Characteristics of Phase Noise • Symbols and Footprints • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
DISCUSSIONS
• AN-808: Multicarrier CDMA2000 Feasibility View all AD9287 EngineerZone Discussions. • AN-812: MicroController-Based Serial Port Interface (SPI) Boot Circuit
SAMPLE AND BUY
• AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs Visit the product page to see pricing options. • AN-835: Understanding High Speed ADC Testing and Evaluation
TECHNICAL SUPPORT
• AN-905: Visual Analog Converter Evaluation Tool Version Submit a technical question or find your regional support 1.0 User Manual number. • AN-935: Designing an ADC Transformer-Coupled Front End
DOCUMENT FEEDBACK Data Sheet
Submit feedback for this data sheet. • AD9287: Quad, 8-Bit, 100 MSPS Serial LVDS 1.8 V A/D Converter Data Sheet
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL IMPEDANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Differential Input Configurations Single-Ended Input Configuration CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/ODM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation SERIAL PORT INTERFACE (SPI) HARDWARE INTERFACE MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations EVALUATION BOARD POWER SUPPLIES INPUT SIGNALS OUTPUT SIGNALS DEFAULT OPERATION AND JUMPER SELECTION SETTINGS ALTERNATIVE ANALOG INPUT DRIVE CONFIGURATION OUTLINE DIMENSIONS ORDERING GUIDE
