Datasheet AD7739 (Analog Devices) - 3
Description8-Channel, 4 kHz, 24-Bit Sigma-Delta A/D Converter
Pages / Page33 / 3 — AD7739. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 8/13—Rev. 0 to …
RevisionA
File Format / SizePDF / 612 Kb
AD7739. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 8/13—Rev. 0 to Rev. A. 5/03—Revision 0: Initial Version
AD7739 Data Sheet TABLE OF CONTENTS REVISION HISTORY 8/13—Rev 0 to Rev A 5/03—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 6 link to page 7 link to page 8 link to page 8 link to page 9 link to page 11 link to page 12 link to page 12 link to page 13 link to page 14 link to page 15 link to page 15 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 19 link to page 20 link to page 20 link to page 22 link to page 22 link to page 23 link to page 23 link to page 23 link to page 23 link to page 24 link to page 25 link to page 26 link to page 26 link to page 26 link to page 26 link to page 27 link to page 28 link to page 28 link to page 29 link to page 29 link to page 29 link to page 29 link to page 31 link to page 31 link to page 16
Features .. 1 Channel Ful -Scale Calibration Registers ... 16 Applications ... 1 Channel Status Registers ... 17 Functional Block Diagram .. 1 Channel Setup Registers .. 18 General Description ... 1 Channel Conversion Time Registers ... 19 Revision History ... 2 Mode Register ... 19 Specifications ... 3 Digital Interface Description .. 21 Timing Specifications .. 5 Hardware ... 21 Timing Diagrams .. 6 Reset ... 22 Absolute Maximum Ratings .. 7 Access the AD7739 Registers .. 22 ESD Caution .. 7 Single Conversion and Reading Data .. 22 Pin Configuration and Function Descriptions ... 8 Dump Mode .. 22 Typical Performance Characteristics ... 10 Continuous Conversion Mode ... 23 Output Noise and Resolution Specification .. 11 Continuous Read (Continuous Conversion) Mode .. 24 Chopping Enabled .. 11 Circuit Description... 25 Chopping Disabled ... 12 Analog Inputs.. 25 Register Descriptions ... 13 Sigma-Delta ADC .. 25 Register Access .. 14 Chopping ... 25 Communications Register ... 14 Multiplexer, Conversion, and Data Output Timing .. 26 I/O Port Register ... 15 Frequency Response .. 27 Revision Register .. 15 Extended Voltage Range of the Analog Input .. 27 Test Register .. 15 Voltage Reference Inputs ... 28 ADC Status Register ... 15 Reference Detect ... 28 Checksum Register ... 16 I/O Port .. 28 ADC Zero-Scale Calibration Register ... 16 Calibration... 28 ADC Ful -Scale Calibration Register ... 16 Outline Dimensions ... 30 Channel Data Registers.. 16 Ordering Guide .. 30 Channel Zero-Scale Calibration Registers .. 16
Updated Format .. Universal Changes to Figure 1 .. 1 Change to ADC Performance Chopping Enabled, Integral Nonlinearity Parameter, Table 1 ... 3 Change to Table 3 ... 7 Deleted Figure 12, Renumbered Sequentially .. 8 Changes to Revision Register Section .. 15 Change to Voltage Reference Inputs Section .. 28 Updated Outline Dimensions ... 30 Changes to Ordering Guide .. 30
Rev. A | Page 2 of 32 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Output Noise and Resolution Specification Chopping Enabled Chopping Disabled Register Descriptions Register Access Communications Register 8 Bits, Write-Only Register, Address 0x00 I/O Port Register 8 Bits, Read/Write Register, Address 0x01, Default Value 0x30 + Digital Input Value × 0x40 Revision Register 8 Bits, Read-Only Register, Address 0x02, Default Value 0x09 + Chip Revision × 0x10 Test Register 24 Bits, Read/Write Register, Address 0x03 ADC Status Register 8 Bits, Read-Only Register, Address 0x04, Default Value 0x00 Checksum Register 16 Bits, Read/Write Register, Address 0x05 ADC Zero-Scale Calibration Register 24 Bits, Read/Write Register, Address 0x06, Default Value 0x80 0000 ADC Full-Scale Calibration Register 24 Bits, Read/Write Register, Address 0x07, Default Value 0x80 0000 Channel Data Registers 16-Bit/24-Bit, Read-Only Registers, Address 0x08 to Address 0x0F, Default Width 16 Bits, Default Value 0x8000 Channel Zero-Scale Calibration Registers 24 Bits, Read/Write Registers, Address 0x10 to Address 0x17, Default Value 0x80 0000 Channel Full-Scale Calibration Registers 24 Bits, Read/Write Registers, Address 0x18 to Address 0x1F, Default Value 0x20 0000 Channel Status Registers 8 Bits, Read-Only Registers, Address 0x20 to Address 0x27, Default Value 0x20 × Channel Number Channel Setup Registers 8 Bits, Read/Write Registers, Address 0x28 to Address 0x2F, Default Value 0x00 Channel Conversion Time Registers 8 Bits, Read/Write Registers, Address 0x30 to Address 0x37, Default Value 0x91 Mode Register 8 Bits, Read/Write Register, Address 0x38 to Address 0x3F, Default Value 0x00 Digital Interface Description Hardware Reset Access the AD7739 Registers Single Conversion and Reading Data Dump Mode Continuous Conversion Mode Continuous Read (Continuous Conversion) Mode Circuit Description Analog Inputs Sigma-Delta ADC Chopping Multiplexer, Conversion, and Data Output Timing Frequency Response Extended Voltage Range of the Analog Input Voltage Reference Inputs Reference Detect I/O Port Calibration ADC Zero-Scale Self-Calibration ADC Full-Scale Self-Calibration Per Channel System Calibration Outline Dimensions Ordering Guide
