Datasheet AD73360L (Analog Devices) - 4
DescriptionSix-Input Channel Analog Front End
Pages / Page33 / 4 — AD73360L. AD73360LA. Parameter. Min. Typ. Max. Unit. Test …
File Format / SizePDF / 304 Kb
AD73360L. AD73360LA. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments. Table I. Current Summary (AVDD = DVDD = 3.3 V)
AD73360L AD73360LA Parameter Min Typ Max Unit Test Conditions/Comments Table I Current Summary (AVDD = DVDD = 3.3 V)
LOGIC OUTPUT VOH, Output High Voltage VDD – 0.4 VDD V |IOUT| ≤ 100 µA VOL, Output Low Voltage 0 0.4 V |IOUT| ≤ 100 µA Three-State Leakage Current –10 +10 µA POWER SUPPLIES AVDD1, AVDD2 2.7 3.6 V DVDD 2.7 3.6 V I 8 DD See Table I NOTES 1Operating temperature range is as follows: –40°C to +85°C. Therefore, TMIN = –40°C and TMAX = +85°C. 2Test conditions: Input PGA set for 0 dB gain (unless otherwise noted). 3At input to sigma-delta modulator of ADC. 4Guaranteed by design. 5Overall group delay will be affected by the sample rate and the external digital filtering. 6The ADC’s input impedance is inversely proportional to DMCLK and is approximated by: (4 × 1011)/DMCLK. 7Frequency response of ADC measured with input at audio reference level (the input level that produces an output level of –10 dBm0), with 38 dB preamplifier bypassed and input gain of 0 dB. 8Test Conditions: no load on digital inputs, analog inputs ac-coupled to ground. Specifications subject to change without notice.
Table I. Current Summary (AVDD = DVDD = 3.3 V) Total Current MCLK Conditions (Max) SE ON Comments
ADCs Only On 25 1 Yes REFOUT Disabled REFCAP Only On 1.0 0 No REFOUT Disabled REFCAP and REFOUT Only On 3.5 0 No All Sections On 26.5 1 Yes REFOUT Enabled All Sections Off 1.0 0 Yes MCLK Active Levels Equal to 0 V and DVDD All Sections Off 0.05 0 No Digital Inputs Static and Equal to 0 V or DVDD The above values are in mA and are typical values unless otherwise noted. MCLK = 16.384 MHz; SCLK = 16.384 MHz.
(AVDD = 2.7 V to 3.6 V; DVDD = 2.7 V to 3.6 V; AGND = DGND = 0 V; T TIMING CHARACTERISTICS A = TMlN to TMAX, unless other- wise noted.) Limit at Parameter TA = –40
C to +85
C Unit Description
Clock Signals See Figure 1. t1 61 ns min MCLK Period t2 24.4 ns min MCLK Width High t3 24.4 ns min MCLK Width Low Serial Port See Figures 3 and 4. t4 t1 ns min SCLK Period t5 0.4 × t1 ns min SCLK Width High t6 0.4 × t1 ns min SCLK Width Low t7 20 ns min SDI/SDIFS Setup before SCLK Low t8 0 ns min SDI/SDIFS Hold after SCLK Low t9 10 ns max SDOFS Delay from SCLK High t10 10 ns max SDOFS Hold after SCLK High t11 10 ns max SDO Hold after SCLK High t12 10 ns max SDO Delay from SCLK High t13 30 ns max SCLK Delay from MCLK REV. 0 –3–
