Datasheet AD9057 (Analog Devices)
Description8-Bit, 40/60/80 MSPS A/D Converter
Pages / Page13 / 1 — 8-Bit 40 MSPS/60 MSPS/80 MSPS. A/D Converter. AD9057. FEATURES. …
RevisionD
File Format / SizePDF / 361 Kb
8-Bit 40 MSPS/60 MSPS/80 MSPS. A/D Converter. AD9057. FEATURES. FUNCTIONAL BLOCK DIAGRAM. 8-Bit, Low Power ADC: 200 mW Typical
Datasheet AD9057 Analog Devices, Revision: D
a
8-Bit 40 MSPS/60 MSPS/80 MSPS A/D Converter AD9057 FEATURES FUNCTIONAL BLOCK DIAGRAM 8-Bit, Low Power ADC: 200 mW Typical V 120 MHz Analog Bandwidth D PWRDN VDD On-Chip 2.5 V Reference and Track-and-Hold AD9057 1 V p-p Analog Input Range 8 Single 5 V Supply Operation AIN T/H ADC D7–D0 5 V or 3 V Logic Interface 1k
BIAS OUT Power-Down Mode: <10 mW 3 Performance Grades (40 MSPS, 60 MSPS, 80 MSPS) VREF IN VREF OUT APPLICATIONS 2.5V Digital Communications (QAM Demodulators) RGB and YC/Composite Video Processing GND ENCODE Digital Data Storage Read Channels Medical Imaging Digital Instrumentation PRODUCT DESCRIPTION
power-down function may be exercised to bring total consumption The AD9057 is an 8-bit monolithic analog-to-digital converter to <10 mW. In power-down mode, the digital outputs are driven optimized for low cost, low power, small size, and ease of use. to a high impedance state. With 40 MSPS, 60 MSPS, or 80 MSPS encode rate capability Fabricated on an advanced BiCMOS process, the AD9057 is and full-power analog bandwidth of 120 MHz, the component is available in a space-saving 20-lead shrink small outline package ideal for applications requiring excellent dynamic performance. (20-lead SSOP) and is specified over the industrial temperature To minimize system cost and power dissipation, the AD9057 range (–40∞C to +85∞C). includes an internal 2.5 V reference and a track-and-hold (T/H) Customers desiring multichannel digitization may consider the circuit. The user must provide only a 5 V power supply and an AD9059, a dual 8-bit, 60 MSPS monolithic based on the encode clock. No external reference or driver components are AD9057 ADC core. The AD9059 is available in a 28-lead sur- required for many applications. face-mount plastic package (28-lead SSOP) and is specified over The AD9057’s encode input is TTL/CMOS compatible, and the the industrial temperature range. 8-bit digital outputs can be operated from 5 V or 3 V supplies. A REV. D Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective companies.
Fax: 781/326-8703 © 2003 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS Typical Performance Characteristics THEORY OF OPERATION USING THE AD9057 Analog Inputs Voltage Reference Digital Logic (5 V/3 V Systems) Timing Power Dissipation APPLICATIONS Evaluation Board OUTLINE DIMENSIONS Revision History
