Datasheet ADUM4190-EP (Analog Devices)
DescriptionHigh Stability Isolated Error Amplifier
Pages / Page14 / 1 — High Stability, Isolated Error Amplifier. Enhanced Product. ADuM4190-EP. …
File Format / SizePDF / 483 Kb
High Stability, Isolated Error Amplifier. Enhanced Product. ADuM4190-EP. FEATURES. GENERAL DESCRIPTION
Datasheet ADUM4190-EP Analog Devices
High Stability, Isolated Error Amplifier Enhanced Product ADuM4190-EP FEATURES GENERAL DESCRIPTION Stable over time and temperature
The ADuM4190-EP1 is an isolated error amplifier based on
0.5% initial error accuracy
Analog Devices, Inc., iCoupler® technology. The ADuM4190-EP
1% accuracy error over the full temperature range
is ideal for linear feedback power supplies. The primary side
Compatible with Type II or Type III compensation networks
controllers of the ADuM4190-EP enable improvements in
Reference output voltage: 1.225 V
transient response, power density, and stability as compared to
Compatible with Distributed-power Open Standards Alliance
commonly used optocoupler and shunt regulator solutions.
(DOSA)
Unlike optocoupler-based solutions, which have an uncertain
Low power operation: <7 mA total
current transfer ratio over lifetime and at high temperatures, the
Wide voltage supply range: 3.0 V to 20 V (VDD1 and VDD2)
ADuM4190-EP transfer function does not change over its lifetime
Output −3 dB bandwidth: 400 kHz typical
and is stable over a wide temperature range of −55°C to +125°C.
Isolation voltage: 5000 V rms reinforced Safety and regulatory approvals
Included in the ADuM4190-EP is a wideband operational
UL recognition: 5000 V rms for 1 minute per UL 1577
amplifier for a variety of commonly used power supply loop
CSA Component Acceptance Notice 5A
compensation techniques. The ADuM4190-EP is fast enough to
VDE certificate of conformity
allow a feedback loop to react to fast transient conditions and
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12
overcurrent conditions. Also included is a high accuracy
V
1.225 V reference to compare with the supply output setpoint.
IORM = 849 V peak ENHANCED FEATURES
The ADuM4190-EP is packaged in a wide body, 16-lead SOIC package for a reinforced 5000 V rms isolation voltage rating.
Supports defense and aerospace applications (AQEC standard) Military temperature range (−55°C to +125°C)
Additional application and technical information can be found
Controlled manufacturing baseline
in the ADuM4190 data sheet.
One assembly/test site One fabrication site Enhanced product change notification Qualification data available on request APPLICATIONS Linear feedback power supplies Inverters Uninterruptible power supplies (UPS) DOSA-compatible modules Voltage monitors FUNCTIONAL BLOCK DIAGRAM VDD1 1 16 VDD2 GND1 2 15 GND2 VREG1 3 REG UVLO UVLO REG 14 VREG2 REFOUT1 4 REF REF 13 REFOUT NC 5 12 +IN Tx EAOUT2 6 11 –IN Rx EAOUT 7 10 COMP
01
GND
0
8 9 GND 1 2 ADuM4190-EP
0- 446 1 Figure 1. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 7,075,329; and 9,293,997.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY RELATED SPECIFICATIONS RECOMMENDED OPERATING CONDITIONS DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
